Results 1 to 5 of 5
Thread: 95 STS Crank sensor,location ??? help
    Nov 2003
    Florida
    35
    Question 95 STS Crank sensor,location ??? help
    Where are the two sensors located on a 95 seville STS, cannot seem to locate them...do you get to them from the top OR bottom of the engine front, side ?????????
    69
    82,278
    Re: 95 STS Crank sensor,location ??? help
    I think they are on the front of the engine.
    Jun 2003
    Texas
    17
    They are just above the oil filter on the side of the block. You get to them from the bottom.
    DaveC
  5. #4
    69
    82,278
    Thanks for the correction Dave. I knew I shouldn't have answered that one.
  6. #5
    Nov 2003
    Florida
    35
    Cool Re: 95 STS Crank sensor,location ??? help
    Found the sensors right above the oil filter and also above the motor mount,,,no way to lift the engine so that I can remove the mount so I guess I'll be taking it to my mechcanic in town this week should not take to long to change with the correct tools,,,no longer having two cars [sold the GN] I don't feel comfortable trying to do it myself and running into problems.......THANKS for the help,,,,,,Robert
  • You may not post replies
