| Re: Installing Oil Pressure Gauge??? It is kind of tough to install. You will have to put a tee in the port where the low oil pressure switch is. That switch is located on the oil filter adapter on the left (front) side of the engine. If you look up at the oil filter and the oil filter adapter above it you will see the low oil pressure switch. Unscrew it and screw a pipe nipple into the hole with a tee for the gauge line and the low oil pressure switch. It is not the easiest spot to get to.....
If you put the gauge on don't be shocked by low oil pressure at idle. The engine is designed to have relatively low oil pressure for fuel economy (less parasitic losses driving the oil pump to needlessly high pressure). The idle oil pressure with a hot engine is down around 5 to 6 PSI so many people freak out thinking it is way low....it is fine. |
