Go Back   Cadillac Owners Group > General Discussion > Cadillac Engine Technical Discussion > Northstar Performance and Technical Discussion
Northstar Performance and Technical Discussion Performance discussions relating to the Northstar System (intake, exhaust, cam, etc.).
Cadillac Forums: HELP! Need serpentine belt diagram
Old 07-20-05, 10:15 PM
View TryMe96Z's Photo Album
Casino Cash: $655
I need a diagram of the layout of the serpentine belt. Front end has had body damage so it is not on the fan shroud. Belt broke so I did not have the chance to draw a picture.
EDIT:
96' STS
  #2 (permalink)
Old 07-21-05, 12:27 AM
View eldorado1's Photo Album
Casino Cash: $5065
Re: HELP! Need serpentine belt diagram
Somethin' like this
  #3 (permalink)
Old 07-21-05, 08:59 AM
El Dobro's Avatar
View El Dobro's Photo Album
Casino Cash: $325
It's basically the same from 1993 on up, so you can check a manual at the auto parts store or another N* Caddy.
  #4 (permalink)
Old 07-21-05, 08:56 PM
powerglide's Avatar
View powerglide's Photo Album
Casino Cash: $275
Is it an easy fix?
My 98 deville probably could use a new belt.....but I am not looking forward to jamming my hand in tight spots and cutting up my knuckles.
Any tips?
  #5 (permalink)
Old 07-21-05, 09:24 PM
View Ranger's Photo Album
Casino Cash: $24216
Originally Posted by powerglide
Is it an easy fix?
Any tips?
I have never tried this but Bbob says to get a lenght of 1/2" copper tubing and flatten the end, then bend it into a small "L" to use to help save your hands and fit into tight places. Sounds like it should work well.
  #6 (permalink)
Old 07-21-05, 09:34 PM
dkozloski's Avatar
Cold Soaked
Cadillac(s): 2006 STS AWD, '95 Ford Ranger
View dkozloski's Photo Album
Casino Cash: $20307
When the belt has cracks in it that are no closer than 1/10 of an inch and it hasn't started to chunk it is at half life and should go another 50,000 miles..
  #7 (permalink)
Old 07-22-05, 05:14 PM
El Dobro's Avatar
Casino Cash: $325
The only real PITA I've found changing a N* belt was with the tensioner. I just remove it until I'm done.
  #8 (permalink)
Old 07-22-05, 10:44 PM
View cadillac_hummer_tech's Photo Album
Casino Cash: $250
here is a diagram for you:
http://www.greshambike.com/images/1996stsbelt.gif
regards
  #9 (permalink)
Old 07-24-05, 10:25 PM
WoodShoe's Avatar
View WoodShoe's Photo Album
Casino Cash: $380
When I replaced mine, I just tied a piece of rope/string to the belt. As i fed the belt through, every time i needed it to move around a pulley, I just pulled on the rope. I left the tensioner to the end, and simply jammed a tool into one of the openings to release the tention. When I first looked at it, I figured it would be a long and frustrating experiance. Since there is limited room. But it only ended up taking about 15 minutes.
  #10 (permalink)
Old 09-29-06, 03:30 PM
rollman's Avatar
Cadillac(s): STS
View rollman's Photo Album
Casino Cash: $360
Thanks for the diagram it sure came in handie today .
Tags: , , ,
belt, diagram, serpentine
