| Re: Overheating: correct diagnostics Yeah, about the only thing to go bad on a water pump is the seal, then it will leak. If it ain't leaking, it's fine, unless the shaft where to break and the impeller stopped spinning. Very unlikely.
Suppliments are added to prevent niusance leaks from porous castings and imperfect gasket mating surfaces. If you don't use them, you may find a minor seepage somewhere. They are just a precaustion on the Northstar but mandatory on the 4.1, 4.5 & 4.9 as a porous casting could leak into the oil which is not possible on the 4.6 due to it's design.
