Originally Posted by qpedd Thanks Boby, DIC gives me Low pressure warning(on display and with alarm sound) when it drops under 5 PSI (I have not noticed a red light) and if I don’t rev it up, engine shots off. I don’t want to do it with my foot on the brake and going to neutral at every stop in a backup can get quite annoying. The problem is more evident when I come off the highway to a stop. Sometime after driving slow for a while and after a few lights, it manages to stay above 5 PSI.
Any thing I’ll have to watch for when I replace these units? Do you recommend changing one first and then the other or go for both?
I used synthetic oil for a while. Last time I used conventional.
Michael, I use FARM filter. Thanks. |
qpedd, bbob is the one to listen to around these parts. As far as using the Fram filter, I have heard and read stuff that scared me away from using Fram filters. You might find this web site interesting, but please don't take it as gospel:
http://minimopar.knizefamily.net/oilfilters.html
I think you'll at least avoid Fram filters in the future. Whether or not it will help your problem I have no idea. This is just FYI. I have personally used the PureONE, AC-Delco, Mobil1, Amsoil, and Wix filters with good success, but then again, I never had any failures with Fram filters either. Happy reading!
