| Re: p076 presure solenoid problem Are you sure that fluid level is fine? Is it possible that it has too high level?
I found that checking of fluid level kinda tricky. It says, that "cold" level doesn't mean the level of not running engine. To check it "hot" engine should work at least 30 min or something like that.
I have problem with transaxle myself now, and when I check level at morning with not running engine I can't even see fluid at all. When transaxle is hot level looks normal, on a hot area of dumpstick. |
