Go Back   Cadillac Owners Group > General Discussion > Cadillac Engine Technical Discussion > Northstar Performance and Technical Discussion
Northstar Performance and Technical Discussion Performance discussions relating to the Northstar System (intake, exhaust, cam, etc.).
Cadillac Forums: Radiator leak...how much $$$?
Old 07-08-05, 04:10 PM
Cadillac Owners Enthusiast
Cadillac(s): 1998 Cadillac Deville Sedan
View weister42's Photo Album
Casino Cash: $630
I have a known leak in my cooling system, started first as a small leak in the transmission cooling line but I think it's getting worse(I can see drip marks on the ground where I parked), the leak is somewhere here(see above) and drips through the bottom of my car along the frame. The tech told me they might have to pull out the radiator and that's going to cost quite a bit. Anyone have suggestions?
  #2 (permalink)
Old 07-08-05, 05:07 PM
View mcowden's Photo Album
Casino Cash: $250
Re: Radiator leak...how much $$$?
Have you already ruled out the water pump or cover leaking? Thermostat cover gasket? Hoses?
You may have already been down these roads, but be sure before you go spending $$$ on the radiator because the water pump can be leaking and dripping down on top of things, and you won't be able to see it unless it's pressurized and actively dripping. Crawl under there and look up at the water pump housing. Is it dry?
Mike
  #3 (permalink)
Old 07-08-05, 08:53 PM
View JEMLRDB17's Photo Album
Casino Cash: $250
Wink Re: Radiator leak...how much $$$?
I have the same issue with my 94 Deville Concours. Not sure what is causing it yet, but I just dropped it off at the auto shop today. I will let you know what he tells me.
  #4 (permalink)
Old 07-08-05, 10:59 PM
Raze's Avatar
Cadillac(s): 90 Eldo -SOLD-, 98 ETC -SOLD-, 86 XR4Ti Track Car, 07 Ranger
View Raze's Photo Album
Casino Cash: $5675
Welcome to the club!
I had a waterpump go, and my radiator go, check the plastic side tanks on the radiator for leaks after the system is hot/pressurized, if it's not coming from there, check the waterpump. The waterpump is cheaper and easy to do yourself provided you have the waterpump tool (can usually rent it from autozone type place for cheap, otherwise buy it for 10-20 bucks). The radiator is a bit more time consuming but easier IMO as all you have to do is drain, disconnect hoses, remove fans, disconnect airbag sensor (just in case), and unbolt it, the cost on the radiator is 300ish, waterpump 120ish, least that's what mine cost but you can always check www.gmpartsdirect.com to get a better idea in case you think a mechanic would rip you off (dealers will so be wary, their parts markups can be 50-100%!)
  #5 (permalink)
Old 07-11-05, 02:20 PM
maydog's Avatar
View maydog's Photo Album
Casino Cash: $250
I have purchased 2 radiators from arrowhead radiator for about $140 shipped. The brand they sell is Silla (they are chinese I believe). I do not have a lot of run time with them but are working ok right now.
  #6 (permalink)
Old 07-11-05, 02:55 PM
Casino Cash: $630
Oaky just got back from the mechanic and he says the radiator needs to be replaced due to a leak on a welded parts Oh and it's leaking transmission oil not coolant, so technicially I can just forget it and just add trans oil every now and then. I believe what he says but replacing a radiator is expensive no? Labor I'm worried about. Should I replace anything else if I get a new radiator? Just got my fuel filter changed and cost me 70 bucks, $46 was for labor.
  #7 (permalink)
Old 07-13-05, 05:20 PM
Casino Cash: $630
Turns out the worst case is mixing coolant and transmission oil...the mechanic called me and said he might be able to match the price for whatever I can find, I serched some stores and they have a choice of heater core and condenser, which is which?
  #8 (permalink)
Old 07-14-05, 09:22 AM
EcSTSatic's Avatar
Cadillac(s): 1999 STS - diamond white
View EcSTSatic's Photo Album
Casino Cash: $13315
So what made you think it was coolant to begin with? Was it a red oily spot or wet green or yellow one?
Niether. These are part of your A/C system. You want a radiator.
Another option might be to install an aftermarket transmission cooler. This would allow you to bypass the internal transmission cooler. Much cheaper fix and better on the tranny.
  #9 (permalink)
Old 08-31-05, 04:50 AM
starfox86's Avatar
Cadillac(s): 2000 sls, 2006 cts-v
View starfox86's Photo Album
Casino Cash: $317
wow,sorry to say,but u got ripped...a fuel filter i believe is like under ten bucks!....and there are just two clips under the car that jus pop off with enough force, and then the new one jus pops right back in. but, i guess you saved ur hands from getting fuel on them...I just bought a new radiator from performance radiator on ebay actually for 122 bucks plus 15 for s/h!!!....what a deal~!...and it is Just like the OEM and i am also having a problem with the loss of trans. fluid in my 94 seville, i see it leaking on the bottom. for now, i just fill it up every other day. which does indeed suck. hopefully urs isnt too bad of a leak.
Tags: ,
$$$, leakhow, radiator
