OK, inquisitive minds want to know..
I tried the WOTs in 2nd gear on my ETC (OBD2), with engine braking on deceleration When I approached redline, it automatically shifted to third... still maintaining the car in third, then downshifting back to 2nd upon release of the accelerator experiencing engine brake (almost as if it was doing PAS, performance algorhythm shifting; however, I don't think the Eldo has that).
I hear some fellow enthusiasts use 1st instead, during jackrabbit starts.. and let the line pressure determine the shift.
Then I hear that if you put the shifter in 2nd, it will start in 1st.
To confuse things futher, if you disable ABS (pull the fuse while car is on), the car starts in 2nd... but is that when in D? what if you put the shifter in 1st? Will it really be 1st, or second after all?
It seems that this tranny has a mind of it's own, with it's best interest in mind. If you read the owner's manual, you will not get much info, other than vague messages that tell you never to downshift at above the gear's range or you risk engine damage that won't be covered by warranty. Is that a blanket statement? Or was it written before they knew the transmission would not allow overrevving?
Is it the tranny itself doing the thinking? or the PCM?
Any stories? Ideas? Facts? bbob? Advanced user tips? When is it really on 1st and on 2nd... for "spirited driving" is 1st or 2nd recommended?
I usually just keep it in D and use the pedal to determine if I want to downshift.
PS on a sidenote I cut-out doing WOTs in 2nd because after a few cycles I noticed my temp gage a notch east and the readout at 238... so I put it back in D and coasted in this Texas heat for a long time until it went back in the 220s (whew!)
