Go Back   Cadillac Owners Group > General Discussion > Cadillac Engine Technical Discussion > Northstar Performance and Technical Discussion
Northstar Performance and Technical Discussion Performance discussions relating to the Northstar System (intake, exhaust, cam, etc.).
Cadillac Forums: Oil Leak
Old 07-07-05, 11:20 PM
View Cruiser's Photo Album
Casino Cash: $250
Oil Leak
Hi All
Just got word from the stealership and they said that the small oil leak that my 95 SLS is from the rear main seal. They want $2800.00 to fix it. The car only has 66000 miles on it.
Has anyone ever had this problem and can you go around it by using some type of seal conditioner?
$2800.00? Are they nuts?
  #2 (permalink)
Old 07-08-05, 12:02 AM
Cadillac(s): 2000 STS, Past : 99 STS, 94 STS
View dwight.j.carter's Photo Album
Casino Cash: $5372
Re: Oil Leak
My mechanic was going to fix that on mine for 1000-1500 and it turned out to be my connectors leaking and that does cost 2000 or more.
  #3 (permalink)
Old 07-08-05, 12:15 AM
Casino Cash: $250
Re: Oil Leak
So did you get it fix or did you find another way around it?
  #4 (permalink)
Old 07-08-05, 12:43 PM
Casino Cash: $250
Re: Oil Leak
Connectors?
  #5 (permalink)
Old 07-08-05, 12:50 PM
View Castro's Photo Album
Casino Cash: $250
Re: Oil Leak
How bad is the leak? An extra quart every now and then isn't so bad.
  #6 (permalink)
Old 07-08-05, 01:11 PM
Casino Cash: $250
Re: Oil Leak
It's not too bad. About 3 or 4 tablespoons everytime I park. I just don't like oil leaks. Many of my friends are hotroders and they say that oil leaks aren't bad, of course hotrods leak oil. They say that it's not leaking oil, it's marking it's territory.
I was hoping to find a seal softener / oil additive to help with the problem.
Any Ideas?
  #7 (permalink)
Old 07-08-05, 01:36 PM
Firewireman's Avatar
View Firewireman's Photo Album
Casino Cash: $250
Re: Oil Leak
I have a bad oil pan gasket on my 99sts. I'd be very interested in an additive to see if it could slow or even fix my leak.
  #8 (permalink)
Old 07-08-05, 01:45 PM
View Ranger's Photo Album
Casino Cash: $24266
Re: Oil Leak
Be careful with additives. Repairs in a bottle, if effective at all, are usually nothing more than a temporary band aid.
  #9 (permalink)
Old 07-08-05, 02:10 PM
Casino Cash: $250
Re: Oil Leak
And I hear they can deteriorate the seals over time, making it worse in the longrun.
  #10 (permalink)
Old 07-08-05, 06:17 PM
Casino Cash: $250
Re: Oil Leak
That's not good. $2800.00 here I come. Damn!
  #11 (permalink)
Old 07-31-05, 03:47 AM
JWH JWH is offline
View JWH's Photo Album
Casino Cash: $250
Re: Oil Leak
Hi!,
Have the same problem in my 97 eldo. Just read where a guy used bars leak and it worked. So I am going to go down tomorrow to walmart and buy some. WE WILL SEE
JWH
  #12 (permalink)
Old 08-01-05, 11:11 AM
View Chrisfor172's Photo Album
Casino Cash: $300
Re: Oil Leak
I had a leak in my 94 sls. I put a couple of bottles of stop leak and haven't seen any more leaks. My mechanic thought it was a gasket or manifold problem. It's OK now.
  #13 (permalink)
Old 08-31-05, 06:51 AM
View rangatang's Photo Album
Casino Cash: $250
Re: Oil Leak
I have had good luck with Lucas Oil Additive.I put in a quart at every oil change and it works good.It will take a couple of weeks but it seems to soften up old gaskets.
  #14 (permalink)
Old 08-31-05, 01:53 PM
Pjs's Avatar
Pjs Pjs is offline
View Pjs's Photo Album
Casino Cash: $250
Re: Oil Leak
Ranger's right. They work by swelling the seals, giving the illusion that your leak is fixed, but after some time the same additives that swell your seals will also deteriorate and dry them out. The only sure fire cure for an oil leak is new seals and gaskets.
  #15 (permalink)
Old 08-31-05, 03:00 PM
View baus's Photo Album
Casino Cash: $250
Re: Oil Leak
i put an additve in my oil to stop a leak and it worked so try it and if it doesnt work than take it in
Tags: ,
leak, oil
