Go Back   Cadillac Owners Group > General Discussion > Cadillac Engine Technical Discussion > Northstar Performance and Technical Discussion
Northstar Performance and Technical Discussion Performance discussions relating to the Northstar System (intake, exhaust, cam, etc.).
Cadillac Forums: Factory air intake box question
Old 07-05-05, 06:10 PM
Cadillac Owners Enthusiast
Cadillac(s): 1998 Cadillac Deville Sedan
View weister42's Photo Album
Casino Cash: $630
I noticed that my air box wasn't sitting flush against the bottom, there's a cooling fin type of deal under the intake hole, I'm guessing it's some sort of air cooler??? Anyways when I tried to mount it back the two rubber legs doesn't pop into their seats, so is leaving it as is be any problems?
  #2 (permalink)
Old 07-05-05, 09:57 PM
View Ranger's Photo Album
Casino Cash: $24241
Re: Factory air intake box question
Just push a little harder or put a light coat of grease on the grommets. What you are looking at under the air box is the PCM and yes it is cooled by intake air.
  #3 (permalink)
Old 07-06-05, 09:47 AM
View mcowden's Photo Album
Casino Cash: $250
Agreed with Ranger, but I would use silicone grease on the grommets because petroleum grease might degrade the rubber. If you look at the bottom of the air box, there are two feet on the left side that make a J shape. On mine, I have to make sure to hook those onto the support frame first, then push straight down on the right side of the box to seat the grommets. It helps if I loosen up the clamp at the MAF to give it a little play. Just make sure you tighten it up again when you're done. I have also accidentally pushed the grommet up through the box before trying to seat them right, so make sure they're sitting in there properly. If the air box sits a little off the thing, I don't think it would be much of a problem unless the temperature is very hot where you are.
Mike
Tags: , , , ,
air, box, factory, intake, question
