Results 1 to 6 of 6
Thread: Oil Life Monitor
    Dadillac's Avatar
    Dadillac is offline Cadillac Owners Connoisseur
    Automobile(s): 2015 Mazda3 S GT Hatchback 2013 Kia Optima SXL
    Nov 2004
    Woodbridge NJ
    51
    2,817
    Oil Life Monitor
    I know, not another oil question. But here goes anyway. I have always read that I should trust the OLM, and change the oil when it is at or near 10 - 5%. I also read that most drivers are getting about 7,000 miles according to th OLM. But, what if my cars OLM is set on a 10,000 - 11,000 range? I bought my car with 50,040 miles, and did the first change at about 58,000, while the OLM still read at about 23%. I am now at 64,500, and the OLM is at about 48%. Can regular plain old dino oil last to 10 - 11,000 miles? Thanks in advance.
    Don
    69
    82,278
    Re: Oil Life Monitor
    I think in 2000 they increased it to 12,500 because of the roller followers thus reducing the shearing effect of the old style lifters on the oil. I am sure GM and the oil companies did plenty of research to be sure it could last that long. They don't make any money replacing engines.
    Dadillac's Avatar
    Nov 2004
    Woodbridge NJ
    51
    2,817
    Double thanks Ranger.
    Don
  5. #4
    Dec 2002
    Fort Lauderdale, Florida
    52
    9,577
    Quote Originally Posted by Dadillac
    Don
    The conventional oils can easily last that long under ideal driving conditions....which is the only time the oil life monitor will actually count down to 0% at 12,500 miles on your car. The oil life monitor was developed considering conventional oils (since that is what is recommended for your engine) so it is accurate for them, yes.
  6. #5
    Dadillac's Avatar
    Nov 2004
    Woodbridge NJ
    51
    2,817
    Thank you BBob. I always knew that oil would last past 3-5,000 miles. I just wasn't sure of 10k +.
    Don
  7. #6
    JohnnyO's Avatar
    JohnnyO is offline Cadillac Owners Fanatic
    Automobile(s): '99 Eldorado, '04 DeVille
    Nov 2003
    Pittsburgh, PA
    194
    I still use Mobil 1. You can't be too careful with these things.
    I changed my dad's at 8000 miles and got a UOA that was pretty good. OLM was down to 16%.
    UOA
  • You may not post replies
