Go Back   Cadillac Owners Group > General Discussion > Cadillac Engine Technical Discussion > Northstar Performance and Technical Discussion
Northstar Performance and Technical Discussion Performance discussions relating to the Northstar System (intake, exhaust, cam, etc.).
Cadillac Forums: Coolant Loss
  #61 (permalink)
Old 11-16-03, 03:20 PM
Cadillac(s): 94 ETC,97 STS
View zonie77's Photo Album
Casino Cash: $7779
Re: Coolant Loss
To loosen, yes it might help. I highly recommend the antisieze before you replace the plugs.
  #62 (permalink)
Old 11-16-03, 03:27 PM
Casino Cash: $7779
Re: Coolant Loss
I don't use AOL. Can I get into AIM with a Yahoo instant message ID?
  #63 (permalink)
Old 11-16-03, 03:34 PM
ShadowLvr400's Avatar
Cadillac(s): 1996 Fleetwood
View ShadowLvr400's Photo Album
Casino Cash: $1142
Re: Coolant Loss
nope, but I have Yahoo messenger as well Shadowlvr400 there too. I've now made a room in yahoo, Phils Repairs
And WD 40 rules!!!! Got plug 8 loosened and free!
  #64 (permalink)
Old 11-16-03, 04:10 PM
Casino Cash: $1142
Re: Coolant Loss
Ok, front set of plugs free, out, and a bit oily...
Now, how am I going to get the rears out? Pull the coil packs and the sway bar?
Oh, can I test the front back, with the back bank still with the plugs in? (The wires have been pulled, so they won't fire)
  #65 (permalink)
Old 11-16-03, 04:34 PM
Casino Cash: $7779
Re: Coolant Loss
You could do 4x4 but it's easier on the starter to pull them all.
Yes, pull the coil pack. It's 3 bolts.
  #66 (permalink)
Old 11-16-03, 04:45 PM
Casino Cash: $1142
Re: Coolant Loss
Front bank Cylinder 8, 120 psi Cylinder 6 140 psi, Cylinder 4 140 psi, Cylinder 2 75 psi...... Going to work on freeing the back bank shortly. I will retest shortly, after pulling everything else, and making sure I had the final one plugged in properly... But that kind of drop is pretty indicative of a head gasket, isn't it? If so, She'll sit while I save up money, and I'll get those performance heads from XMS. And try to do a changeout myself.
  #67 (permalink)
Old 11-16-03, 05:47 PM
Casino Cash: $1142
Re: Coolant Loss
Rear bank, 1-130 psi, 3-90 psi, 5-120 psi, 7-130 psi
  #68 (permalink)
Old 11-16-03, 06:32 PM
DaveSmed's Avatar
Got Torque?
Cadillac(s): 1968 Cadillac Sedan deVille, 1994 Chevrolet G20
View DaveSmed's Photo Album
Casino Cash: $1700
Re: Coolant Loss
Oh well. Look at it as an oppurtunity to install the timeserts, install some copper headgaskets, and then crank up the nawws. What do the XMS heads have done to them? Port and polish? Larger valves?
  #69 (permalink)
Old 11-16-03, 10:53 PM
elwesso's Avatar
Cadillac Owners Master
View elwesso's Photo Album
Casino Cash: $310
Re: Coolant Loss
Yeah, you got 2 cylinders that are really low.... Start saving money!!
  #70 (permalink)
Old 04-23-05, 07:49 PM
chevyorange's Avatar
View chevyorange's Photo Album
Casino Cash: $275
Re: Coolant Loss
Thanks for the great thread. I think my 94 STS with *gasp* 91K is having this problem... disappearing coolant with no leak.
BAH!
  #71 (permalink)
Old 04-29-05, 10:01 PM
PhillyCaddy's Avatar
Cadillac(s): 1994 SLS
View PhillyCaddy's Photo Album
Casino Cash: $325
Re: Coolant Loss
well after reading every post in this thread, I now know what I have to test for, but I think I already know what the answer will be...HEAD GASKETS
I am blowing water out of the coolant tank at high speeds and high revs. also it is overheating.
I will do the compression test now.
Tags: ,
coolant, loss
