Results 1 to 4 of 4
Thread: Forged crankshaft for N*
    May 2005
    21
    Does any one know what 2004 N* engines have the forged crankshaft? Was it only in the RWD engines or did all 2004 engines (LD8 and L37) get them?
    Sep 2003
    1,471
    Re: Forged crankshaft for N*
    I believe the forged cranks were in all the N* starting in 2000.
    Dec 2002
    Fort Lauderdale, Florida
    52
    9,577
    Not 2000. The forged crank was used in all 2004 and later Northstar RWD engines and went into production in 2004 FWD engines mid model .
    You cannot use the forged FWD crank in a 93-99 engine due to the fact that the reluctor wheel pattern machined into the forged crank is totally different in tooth count and pattern. The crank sensors and ignition system on the 93-99 engines will not work with the forged crank reluctor wheel pattern at all.
  5. #4
    Feb 2004
    FL
    2,250
    Why would you even want a forged crank? Are you aiming for 2000hp or something?
  • You may not post replies
