Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Thread: Spark Plugs on 94 STS.
    Feb 2004
    North of Philly
    493
    I've read the thread on changing out the spark plugs, and it looks pretty straight forward. However, my mechanic refused the job because he says it's too hard to get the back bank of plugs out.
    What's the real deal on these things?
    Sep 2003
    Hermosa Beach, CA
    2,721
    Re: Spark Plugs on 94 STS.
    sounds like a lame mechanic.
    Just remove the ignition coil packs (also the cross brace if you want to) its a breeze.
    I did it curbside in the middle of winter (it was a 98 deville but may be similar to yours)
    DIY costs about 130 bucks
    Mechanic/dealer will charge about 400 bucks or more
    69
    82,262
    I did mine without removing anything (except the plugs). Just needed a 6" extension. It's a straight shot at the plugs. Much easier than it looks.
  5. #4
    Feb 2004
    FL
    2,250
    Quote Originally Posted by ktills45
    hahahahahaha! What a tard! I can list 10 cars by memory that have such bad and misplaced plugs that it would make a kitten swear.
    Read: get a new mechanic, and never look back.
  6. #5
    Spyder's Avatar
    Spyder is offline Cadillac Owners Master
    Automobile(s): None now...1972 Challenger=my pride and joy.
    May 2004
    Sonoma Co, CA
    34
    5,688
    A cow magnet works wonders too...stick it to the end of your extension, then drop both down the hole, pulls the old plug out like nothing...just don't forget to take it out from under your hood, so when you close the hood at a gas station in the middle of Death Valley on a roadtrip to Vegas you don't bend the hinge, causing it to stick up a quarter of an inch on the drivers side. Don't ask how I know that's possible.
  7. #6
    Sep 2003
    Hermosa Beach, CA
    2,721
    is this a dumb question: whats a cow magnet?
  8. #7
    Sep 2003
    Metro ATL
    4,854
  9. #8
    Sep 2003
    Hermosa Beach, CA
    2,721
    please tell me those things don't get rammed up the cows @ss!?!
    Holy smokes!
  10. #9
    Sep 2003
    Metro ATL
    4,854
    That would be the wrong end of the digestive system.
  11. #10
    Feb 2004
    North of Philly
    493
    Thanks for the replies.
    I had the engine cover off last nite, looks pretty easy once the strut and coil pack are out.
    BTW, any reason for gas/liquid to be on the outside of those plenum runners under the cover? I kind of figured that area should basically be dry...
  12. #11
    Feb 2004
    North of Philly
    493
    Quote Originally Posted by eldorado1
    I've perhaps given you the wrong impression of this mechanic.
    He's actually a great mechanic, for two very important reasons.
    1) He knows what he can do, and when he performs those repairs they stay repaired. In 10 years, I've never had to have any additional work done which he had fixed. He also knows what he's not comfortable working on, and tells me flat out that he isn't.
    2) I can trust him completely.
    I realize it might seem odd that he wouldn't take this job, but he's older, old school and doesn't like the N* at all. I think the complexity gets to him, and he's not willing to work on something which might end up getting him in trouble and costing me more money then it should.
    That said, I will have to start hunting for a dealer to start doing service work on this car, as well as the CTS.
  13. #12
    zonie77 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 ETC,97 STS
    Sep 2003
    Arizona
    3,531
    You might give it a try yourself?
  14. #13
    Dec 2002
    Fort Lauderdale, Florida
    52
    9,577
    I would say, without bias, that the spark plugs on the Northstar are about the easiest plugs in the world to change....especially for a V8. Other things are harder to do maybe but the plugs are a breeze to change.
    You really shouldn't be pulling the silver top cover unless absolutely necessary to get inside the intake manifold. It is absolutely unnecessary to take the top cover off to change the plugs.
    The silver top cover on your engine (93 and 94) is actually the top of the intake manifold. The silver top cover is a functional part of the intake manifold. The tubes you mention are usually covered with an oily film as they are INSIDE the intake manifold. The silver top cover on the 95 and later engines is primarily a beauty cover but on yours it is a functional part. Don't even think of starting the engine with the silver cover off as the engine will be unthrottled and you will experience of a runaway engine bouncing off the rev limiter if you start it with the cover off.
  15. #14
    Feb 2004
    North of Philly
    493
    Quote Originally Posted by zonie77
    Pfft, that was the entire point of this post. :rolleyes2
  16. #15
    Feb 2004
    North of Philly
    493
    Quote Originally Posted by bbob
    Um, yeah I found that out once I pulled it off.
    Guess I need to invest in a torque wrench now.
    I was going by the link in the tech archives for pulling the plugs, I initially thought the cover was a beauty cover. Seemed to be torqued down damn tight for a beauty cover though.
    Anyhow, just rolled 132k. Plugs are coming out this Saturday or Sunday, thanks for the input.
  • You may not post replies
