Results 1 to 3 of 3
Thread: 94 deville intake cover
    jspano's Avatar
    jspano is offline Cadillac Owners Fanatic
    Automobile(s): 1994 Deville
    May 2005
    spring hill,fl.
    60
    169
    the intake manifold has an aluminum cover
    then there is a waffer that channels the electric wiring
    (i think for the injectors) someone has removed this at one time
    and the gasket is compromised on the one side for sure
    and the bottom side i think what effect would this
    have on the engine
    thanks
    jspano
    growe3's Avatar
    growe3 is offline Cadillac Owners Enthusiast
    Automobile(s): 1993 STS and 2004 DTS
    Oct 2003
    Cameron Park, CA
    564
    Re: 94 deville intake cover
    The "waffer" is the fuel rail. It is expensive $$$ to replace.
    A leak at the top cover is a vacuum leak. A small leak will possibly whistle and suck in small dust particles; which is bad for the engine. A larger leak will make more noise and upset the air/fuel metering to the engine.
    If the fuel rail damage is only to the silicone seal, you can carefully clean the fuel rail with spray brake cleaner to remove all oil residue. Then apply a small amount of silicone gasket sealer to the damaged area. Be sure the silicone sealer states that it is safe to be used for cars with oxygen sensors.
    -George
    jspano's Avatar
    May 2005
    spring hill,fl.
    60
    169
    george is it ok to lift off the fuel rail it seems to be stuck on the drivers side
  • You may not post replies
