Page 1 of 2 12 LastLast
Results 1 to 15 of 30
Thread: Oversize pistons? Undersize bearings?
    Jan 2005
    Southern Oklahoma
    64
    84
    Does anyone know of any company that manufactures and/or markets these items for the '92-'99 N* engine? Thanks!
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,283
    Re: Oversize pistons? Undersize bearings?
    Check the dealer and the auto parts stores. My nephew manages the second most profiable NAPA store in the world and they specialize in locating hard to find parts. Go to a big central store that services the commercial accounts. Big automotive machine shops are also well connected in this area.
    Jan 2005
    Southern Oklahoma
    64
    84
    My local GM dealer tells me that oversize pistons/undersize bearings are not available from GM, and my NAPA store tells me that the only thing they can find is .025mm under main bearings. I have also checked several websites of piston manufacturers, hi performance parts distributors, etc., with no luck.
    Also, do you know if '93-'94 N* engines were 4.6L? I've been told they were 4.9L during the first two years of production. And what the HP ratings are for these engines? I understand there are two basic models: 295 HP for the DeVilles, and hotter cam/higher HP versions for the SeVilles and Eldo's. Thanks from a Caddy fan in training! *lol*
  5. #4
    Dec 2002
    Fort Lauderdale, Florida
    52
    9,577
    I think that undersized bearings and oversized pistons are pretty hard to find...there just isn't much call for them.
    All Northstar engines were 4.6 liter. During 1993-1995 both the Northstar and the 4.9 liter pushrod engine were produced but they are not the same, not even related... There was never a 4.9 Northstar despite rumors to the contrary...
    In 1993/94 the Northstar engines were rated at 270 HP (LD8) and 295 HP (L37). In 1995 the engines gained a little power with the intake manifold redesign so that they were rated at 275 and 300.
  6. #5
    Jan 2005
    Southern Oklahoma
    64
    84
    Thank you, gentlemen, for your input and information. In glancing through the Service Manual, I see some pretty tight tolerances for crank journals, cylinder bores, etc. Am I to assume, from the lack of availability of oversize/undersize parts, that these Northstar engines hold their tolerances much better than engines typically do? It seems to me that any wear at all will put a crankshaft or a block out-of-service according to the service limits published in this manual. In what kind of condition have you been seeing these engines in after 100K miles? Or 200K? I realize there are a lot of variables that will affect the service life, but I'm speaking in general terms here. You guys have been fooling with these Northstars long enough to see how they hold up. What have you seen? Thanks!
  7. #6
    Dec 2002
    52
    9,577
    I think that you will find that general clearances inside the engine stay pretty close to the original specifications. Cylinder bores typically still have the factory hone pattern in them and no ridge at the top of the cylinder at all with 150K on the motor. Crank journal wear is negligable. Pictures are posted on forum of main bearings with over 100K on them and they are good enough to reuse. From a wear and tear standpoint there is little to remachine or refresh on most engines unless there is some sort of failure that creates collateral damage.
  8. #7
    Jan 2005
    Southern Oklahoma
    64
    84
    Thanks, Bbob. Your expertise is much appreciated, as always. Just a couple more questions: I'm sure the electronics would be different, but are all the basic, N* engines physically interchangeable between '93 and '99? And could I expect a '99 STS PCM to re-learn on an engine out of a '93 DeVille and function ok, aside from the obvious drop in HP, that is? Thanks again!
  9. #8
    Loose screw is offline Cadillac Owners Fanatic
    Automobile(s): 94 concourse, 99 sts
    Feb 2004
    60
    150
    One thing Bbob had previously enlightened us about, was the crank should not be turned. The crank has "rolled" fillets to strength them (pre-stress them I think) and turning down or welding the crank will not only mess that up it can cause the crank to change shape and not be true and will weaken it. That is one reason undersized bearing are not available fro GM. Also never undo a rod to take a look at the bearings, the rod bearings MUST be repalced if they have been run in the engine and the rod caps opened. The bearing are cruch fitted in the rods and will loose that if the opened and they will spin if you resuse them after loosening the rod cap and retightening. Also rings show very little wear and seldom have to be replaced. Most of the time they are just stuck from cabon which can be corrected without tearing the engin down. So if you are burning oil or have low compression try that first.
  10. #9
    Dec 2002
    52
    9,577
    Quote Originally Posted by mechanix
    Well.....there are some differences in the PCMs and such that make this an un-simple answer. The 93/94/59 engines and PCM's were a speed density fuel injection system that did not use a mass air flow sensor. The 96-99 engines use mass air flow and are OBD2 compliant. In any given model car the controller and calibration won't care which "engine" is in the car...i.e..the complete engine mechanical assembly.... as the control system will operate fine. So, if one were to put a 95 Northstar into a 97 model car you would want to use the mass air flow meter and such off the 97 model car and hook everything up to the 95 engine and it would run fine....and vice versa. If you took a 97 and put it into a 95 then you would just delete the mass air flow sensor and hook the mechanical engine assembly up to the electronics of the 95 and it would be fine. No "learning" to do as the computer wouldn't know the difference. The 93/94 Northstars had a large plenum style intake with the silver top cover actually the working cover of the intake manifold with the plastic tuning tubes for each cylinder inside the manifold enclosure. This arrangement was replaced with the single piece injection molded plastic intake manifold for 1995 that has been used since then. The heads and EGR system changed a bit with the manifold change. There is no real controller problem with interchangability of the 93/94 engines with others (they were speed density systems) but the actual hardware is hard to interchange as part of the injector wiring harness and sensors and such were all inside the intake manifold on the 93/94 and that stuff moved outside on the 95 and later. But it all can be cobbled to work in a fashion.
    Just to clear things up....the crank isn't a throwaway and can be reground slightly...it just needs to be judicious grinding and the optimum situation is to have the fillets re-rolled after grinding. The 4.5/4.9 cranks were also rolled fillet cranks and they are routinely ground undersized and re-rolled at the engine re-man facility. Just that most crank shops do not have the necessary equipment and tooling to re-roll crank fillets so it is a bit restrictive of a re-work.
    Cracked cap connecting rods are also a bit different to re-man since the cracked surface of the cap cannot be machined to gain material for re-sizing the bearing bores so a special bearing that is undersized (for crank journal resizing) and oversized on the OD (for rod bore re-sizing) must be developed.
  11. #10
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,283
    What causes fatigue cracks is stress reversal. Rolling the fillets introduces controlled stresses into the fillets that are high enough that they do not reverse in use. Welding in the fillets relieves these stresses as does machining. Now the crank will fatigue crack. I have seen cranks with rolled fillets that have been carefully ground 0.010" under and left the fillets untouched that worked out okay. I also had a rolled fillet crank with a spun rod bearing that was repaired with welding by an absolute artist that confined the welding to the journal with none in the fillets. As a general rule, rolled fillet cranks are not repairable in the field.
  12. #11
    Feb 2004
    60
    150
    Thanks for the additional information. I have been try to find out online for some time now what exact part of the journal is the fillet, the term is to me or I have just forgot what it is. I am assuming it is the oil hole? fill-et - fills the journal with oil, am I right?
    But I did find a good 2002 article with great pictures of inside of the engine.
    http://www.autospeed.com/cms/A_1569/article.html
  13. #12
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,283
    The fillet is the junction between the bearing journal and the crank cheek.
  14. #13
    Feb 2004
    60
    150
    I thought that at first because that is where I could see stress having a big part to play but the name got me so on the Northstar it is groves on the edges of the journal. and rolling process pushes hard on this areas - depressing it, right? I think I go the whole picture now.
  15. #14
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,283
    The rule of thumb in aircraft is that once a fatigue crack starts at a fillet, the crank will fail in 75 hrs. running time. The most startling crankshaft story I have heard: The Continental factory test engineers had a six cylinder crank set up on an electronic shaker table(imagine a super sized radio speaker armature that applied twist or torsion to the crank). When the applied frequency of the torsional shaking reached the resonant frequency of the crank it could be seen with the synchronized strobe light that the crank was winding and unwinding a quarter of a turn. All the engineers turned and ran. This story was related to me by the runner in the lead.
  16. #15
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,283
    Because the resonances and harmonics of crankshaft torsional vibration can cause exceedingly high stresses in propeller blades, aircraft engines have all sorts of ocsillating vibration dampers like pendulum weights, caged ball bearings, high hysteresis rubber couplings, and the lord knows what. Automobile engines are not immune. Early DOHC Ford Indy engines had extreme dynamic variations in valve timing due to torsional resonances in the cam drive train. Chevrolet/Ilmore had the luxury of witnessing all these monkeyshines so they came up with the elegant solution of driving the cams and accessories off the flywheel end of the the engine.
  • You may not post replies
