Results 1 to 6 of 6
Thread: What mods is available for my 94 SLS ???
    Feb 2005
    1
    What mods is available for my 94 SLS ???, im a new caddy owner and i notice a very impressive performance from this type of car but i want to improve it !, What is available at this time, air intake- exhaust- custom chip ????? Please let me know and where is the best place to find it, also i live in canada and i dont know if only canadian sls do this but when i reach 180 KM/H i found a cut-off, i cant go higher, what i have to do to remove this
    thanx for your help
    Feb 2003
    46
    Re: What mods is available for my 94 SLS ???
    The best mods are low restriction exhaust (mufflers and high flow cat) and torque converter (something like a Yank.) Chips are available for your year but dont provide any additional straight line acceleration. If you want to remove the speed limiter that is in the chip. The bigger STS cams and gear set can be used with a different PROM but personally I prefer the SLS motor. The torque convertor is a great equalizer here. Also don't change the cams or increase the rev limiter without verifying that your year has the better valve springs. The early LD8 motors had weaker springs.
    HTH
    John
    danbuc's Avatar
    danbuc is offline Cadillac Owners Connoisseur
    Automobile(s): '87 Jeep, '10 Thruxton, '00 Duc 748, '01 748R (853cc)
    Mar 2004
    Mahwah, NJ
    32
    3,703
    You will never gain the full 25hp from the cam change. Even if you did, your taller final drive ratio would limit what actual benifit it would have.
    take a look at my reply to this thread http://www.cadillacforums.com/forums...read.php?t=357
    These sites, along with http://www.fastchip.com/ and http://www.superchips.com/html/mainpage/index.htm are the only real places to find aftermarket parts.
  5. #4
    Feb 2003
    46
    Sorry if I wasn't clear. Change the chip cams springs and gear at the same time. This plus the 2000 RPM stall are the differences between the 275 and the 300 horse motor. Stock STS Zrated chip works just fine for the swap. I would not waste my money on an aftermarket chip.
    John
  6. #5
    skemp is offline Cadillac Owners Member
    Automobile(s): 1994 Seville
    Oct 2004
    Dresser, WI
    31
    8
    Where would this 'chip' be found? I am speaking of the speed-limiting device. I have a guy with a 96 STS for parts that I could maybe swap one out for. Is this the PCM itself and will everything else function the same beside the speed limit?
  7. #6
    danbuc's Avatar
    Mar 2004
    Mahwah, NJ
    32
    3,703
    That PCM will not work with your car since it is OBDII, and your car is OBDI. Even if it was from a 1995 STS (which is OBDI), the PCM would still not function properly with the engine in your SLS. This is because it is programmed for the different intake cam, timing, transmission,...ect in the STS. The OBDII cars, do not have a removable EEPROM chip like the OBDI cars did. This means that is must be reflashed with a scantool, instead of just swapping out a chip like the 1995 and older OBDI cars.
  • You may not post replies
