Results 1 to 2 of 2
Thread: Original or swapped N*
    cl1986's Avatar
    cl1986 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 Eldorado, 94 SLS got crushed
    Jun 2003
    South Dakota
    38
    1,485
    How woudl i know if my car has the original motor or a swapped out motor?? Where is the engine id number, and what would that match up with??
    Dec 2002
    Fort Lauderdale, Florida
    52
    9,577
    Re: Original or swapped N*
    On a Northstar the VIN of the original car is stamped on the side of the engine block down low on the right (rear) side of the block near the lower crankcase split line. You can probably see it thru the right front wheel well if you remove the tire and pull the splash shield back and look at the engine block beside the trans case.
  • You may not post replies
