Results 1 to 3 of 3
Thread: check engine soon
    98deville is offline Cadillac Owners Member
    Automobile(s): 1976 eldorado conv., 1998 deville, and a 2003 dts
    Dec 2003
    texas
    34
    8
    check engine soon
    My CHECK ENGINE LIGHT came on the other day, I pressed the off & warmer buttons and pulled up these codes:
    PCM P0122
    P0463
    P0603
    P1599
    ACM B1348
    SDM B1147
    B1148
    B1327
    Anyone Know what would cuase the air bag malfunction, low voltage and all that? And what can I do to fix it? I also recently changed my Coolant.. and cleaned the tb and egr valve.....could it be that i disconnected the connectors on the tb and egr valve?
    mcowden is offline Cadillac Owners Connoisseur
    Jun 2003
    1,164
    Re: check engine soon
    Are the codes current or history? If they're history and you don't remember these things happening recently, clear them out and get them again if the SES light comes on. The throttle position sensor or stall codes would turn on SES, but the 463 and 603 won't as far as I know. So whichever of those is happening is the one to troubleshoot. Just need to know which it is. The throttle position sensor is on the throttle body. Is it reconnected properly? Was the ignition turned on when you disconnected the sensor?
    You didn't mention any symptoms. How is it running? Did you really have a stall? Anything going on other than perfectly normal operation?
    B1348: Very low AC refrigerant pressure - I think you can figure that one out
    B1147 and B1148: Driver and passenger side airbag malfunction - I don't know about this one. Is it current or history? Maybe the sensor is bad or there's a wiring problem somewhere in the circuit. Check the fuses. Can't think of a good way to troubleshoot it. Anyone else with ideas here?
    B1327: Voltage below 9 volts - I dunno about this one either. Maybe set during a start on a cold morning? How old is the battery? Has the ignition beel left on for an extended period of time without the engine running? Perhaps when you cleaned the TB and unplugged the TPS? Is it current or history?
    Mike
    Jan 2005
    over on the south 40
    154
    603 is battery reset
    1599 is stall code
    463 I think is fuel pump ckt
    122 I'll have to get back to you on that one
    Any way, disregard the 603, and 463. They will cause no problems.
  • You may not post replies
