Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Thread: Lurching idle
    Dadillac's Avatar
    Dadillac is offline Cadillac Owners Connoisseur
    Automobile(s): 2015 Mazda3 S GT Hatchback 2013 Kia Optima SXL
    Nov 2004
    Woodbridge NJ
    51
    2,817
    Lurching idle
    For several weeks now my 2008 N* has been idling poorly. For a lack of a better word it is lurching at idle. In gear or park doesn't matter. But it is more pronounced in gear. The rpm doesn't change but it feels like the car wants to start driving on its own. These are brief occurances but frequent. Once I give it throttle all is fine. Since I thought it seemed like a vacuum leak I have already changed the intake plenum, intake manifold gaskets, MAP sensor, also changed the crankshaft position sensor, both knock sensors, camshaft position sensor, wiring harness for these sensors, thorughly cleaned the throttle body and the EGR and the MAF. Next on tap is to change the throttle body gasket. I also bought 4 injectors to swap out a side at a time. This issue still persists and I am wondering if I am missing something. Any help would be appreciated. Thanks
    Don
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,842
    Re: Lurching idle
    Don ........... Long shot, but what about a bad resistance strip in the TPS ? The PCM could be "hunting" for an idle reference.
    ............ but the "no rpm change" thing is a mystery.
    Dadillac's Avatar
    Nov 2004
    Woodbridge NJ
    51
    2,817
    Re: Lurching idle
    Yeah I know right. I think I am going to do the gasket change and injector swap and if I still get nowhere it is time to have the dealer check it out. I just know that it is gonna cost a metric ton to have it fixed there. And that is if they diagnose it right the first time.
    Don
  5. #4
    69
    82,272
    Re: Lurching idle
    No DTC's?
  6. #5
    Dadillac's Avatar
    Nov 2004
    Woodbridge NJ
    51
    2,817
    Re: Lurching idle
    No DTC's. That is what is killing me. This is one time I was praying for a code to set. Anyway I changed the throttle body gasket today. Also cleaned the throttle body AGAIN. Damn they get dirty fast. But no change. I then swapped the four right side (rear) injectors. Although it feels like the issue is resolved I will hold elation until driving the car a few days. Once before I thought it was repaired only to have the issue resurface.
    Does anyone know it the injectors has a bench test procedure? Like a resistance check? Or do they need to be on the vehicle to test them? I have a DVD repair manual and the test procedures listed are either on the vehicle or with some fancy test equipment that I do not own. But a simple resistance check I can do. Would be nice to know if one or more injectors are just dirty needing cleaning or faulty
    Don
  7. #6
    Feb 2006
    56,842
    Re: Lurching idle
    I think our injector coil resistance should be 11 - 14 Ohms.
  8. #7
    Dadillac's Avatar
    Nov 2004
    Woodbridge NJ
    51
    2,817
    Re: Lurching idle
    Quote Originally Posted by Submariner409 View Post
    But is that a bench test procedure or an on the car one? The manual I have kind of makes it seem that you use the Tech 2 for that. Just wondering
    Don
  9. #8
    Feb 2006
    56,842
    Re: Lurching idle
    An unplugged injector should measure XX Ω across the two terminals either in the manifold or on the bench.
  10. #9
    Dadillac's Avatar
    Nov 2004
    Woodbridge NJ
    51
    2,817
    Re: Lurching idle
    Okay so I changed out the 4 injectors and my problem is 90% cured. Do not want to deal with this anymore so I am buying 4 more. Anyway I tested the 4 old ones. Three of the tested at 11.9-12.3 ohms. The other one went between 11.9 and infinity. Couldn't get it to stay in spec for more than 10 seconds or so. It was bouncing all around. Then I decided to check the other four that I didn't change. Since I had just drove the car the engine was hot. All four tested at about 14.8 or so. I am guessing because of the heat. Also didn't keep the multimeter on there too long because of the heat so I couldn't check for variances over time. Anyway there are 4 more injectors in my future. I will post again once I get them and install them.
    Don
  11. #10
    69
    82,272
    Re: Lurching idle
    WOW! Injectors are pretty reliable. I'm surprised to hear that.
  12. #11
    Dadillac's Avatar
    Nov 2004
    Woodbridge NJ
    51
    2,817
    Re: Lurching idle
    Me too. I would have bet the farm it was a vacuum leak. Injectors didn't even cross my mind. Hoping that changing the other four makes the issue 100% fixed.
    Don
  13. #12
    Dadillac's Avatar
    Nov 2004
    Woodbridge NJ
    51
    2,817
    Re: Lurching idle
    Ended up being a severe misfire on cylinder 8. And a miniscule misfire on cylinder 1. Dealer installed a good used coil in 8 and the issue is 99% gone. So I bought two coils and when they arrive I will install them in 1 and 8. I will return the used coil to the dealer. But finally it is nice to have a properly functioning Cadillac again
    Don
  14. #13
    Dadillac's Avatar
    Nov 2004
    Woodbridge NJ
    51
    2,817
    Re: Lurching idle
    Replacing coils 1 and 8 fixed the issue. Engine runs butter smooth again.
    Don
  15. #14
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,993
    Re: Lurching idle
    The individual coils on newer cars die all the time. Beauty covers covering everything and they don't help dissipating heat. Plastic is a lousy thermal conductor. And in most cases they even have those sound deadening material, which also provides a good heat insulation...
    I have seen several cars having dead coils within a few years, most of them having individual coils on plug covered by engine beauty covers. Never had any problem with exposed 99 coil packs, or 00 ICM with heat sinks.
  16. #15
    ryannel2003's Avatar
    ryannel2003 is offline Cadillac Owners Connoisseur
    Automobile(s): 2016 Honda Accord LX. Previous: 2004 Deville, 2000 STS
    Apr 2007
    New Bern, NC
    27
    3,718
    Re: Lurching idle
    Funny you mention that Harry... according to the previous work history on my Deville a few of the coil packs have already been replaced. It was the same situation with my BMW as well.
  • You may not post replies
