Page 5 of 6 FirstFirst 123456 LastLast
Results 61 to 75 of 89
Thread: Custom Intake Finished!
  1. #61
    Jan 2003
    Newtown, PA
    58
    6,472
    Real bad place for a filter dude.
    BTW, am I nuts or do you have a nitrous kit on this car?
  2. #62
    elwesso's Avatar
    elwesso is offline Cadillac Owners Master
    Automobile(s): 2005 CTS-V, 1994 Infiniti Q45
    Jan 2003
    Indiana
    7,661
    I cant think of a worse situation, KC!!
  3. #63
    kcnewell is offline Cadillac Owners Connoisseur
    Jan 2003
    Nevada, Still the land of the free!
    2,235
    I.......Am Speechless!
  4. #64
    elwesso's Avatar
    Jan 2003
    Indiana
    7,661
    Is your makeup running again?
  5. #65
    Jan 2003
    2,235
    Tears from the laughter!
  6. #66
    elwesso's Avatar
    Jan 2003
    Indiana
    7,661
    Thats right. What could be worse than running out of twinkies on a rainy day?
  7. #67
    Jan 2003
    53
    Well... I'll just have to run w/ an umbrella to the store. hehe. I guess I'll need the running after eating a box of twinkies
    Edit: You are correct. I'm currently running a 100 shot wet kit nitrous set up.
  8. #68
    Jan 2003
    Newtown, PA
    58
    6,472
    Have you ever gotten any E/T's with and without the kit? I'd be interested to see what kind of improvement you got.
    Also, I hope you're preparing for the head gasket R&R that is surely coming
  9. #69
    Jan 2003
    53
    No E/T's yet. I'm hoping for mid-high 13's on the spray. The ultiamte goal for the car is high 12's so I need some more mods to get me there still Any ideas anyone? Maybe custom heads/cam work
  10. #70
    Jan 2003
    2,235
    Earlier in this thread I made a remark that people should not try to change what they do not fully understand. This is a perfect example of what I was referring to! Having seen the photos of this intake I see NOTHING there that will improve this vehicle at all! To the contrary this car now has an intake outside under the car directly in the path of anything that bounces off the wheels or the wheels of the car in front..Great idea! Congratulations! You are now the proud owner of a fine american luxury car that you take a chance of destroying simply by the act of driving it under normal circumstances. These forums are partially here as a tool to use to learn about what will and will not work to improve your car and make it more user friendly. We've almost all said in one way or another that this IS a BAD idea! All I can say at this point is....Good Luck! Let us know when it grenades! I for one will be on record as having already said "I told you so"
  11. #71
    jadcock's Avatar
    jadcock is offline Cadillac Owners Connoisseur
    Automobile(s): White Diamond 2001 STS
    Jan 2003
    North Carolina
    38
    1,317
    Hey, can I get in on that "told ya so" action too? :banghead2
  12. #72
    Jan 2003
    53
    That's fine.
    As such, you should not try to modify your car, because it is clear you do not understand the underlying principles of cold air induction.
    However, if I have to do a little more maintenance of my car in order to assure it's running properly, it bothers me not.
    It's a bad idea b/c I have to be more careful and maintain my car more often? Doesn't sound like a bad price to pay for the advantages it gives me.
    If you don't like what I do, don't respond.
  13. #73
    jadcock's Avatar
    Jan 2003
    North Carolina
    38
    1,317
    No, but I do understand the principles of rock induction, road grime induction, and induction of other road surface anomalies and know that I don't want those types of intakes on my car.
    Dude, we're not saying that the idea sucks -- just that there might be a better place for the filter as opposed to suckin' ants off the road surface. If it works for ya, that's all that counts.
  14. #74
    Jan 2003
    Newtown, PA
    58
    6,472
    I understand what you're saying. BUT, I'd be VERY careful with an air filter positioned so low and in such a position. The dirt etc. is no biggie as you said. So you keep a closer eye on the filter, so what? The real problem is what happens to your engine if it were to ingest a significant amount of water (which can happen pretty easy with your filter location). Suddenly hydro-locking your engine would be disasterous.
  15. #75
    elwesso's Avatar
    Jan 2003
    Indiana
    7,661
    I do have a suggestion that would make this work better. Raise the filter higher, and then put a hose over the filter going down to the road level. Then at the end put some sort of screen over that. That wouldnt necessarily eliminate the possibility for hydrolocking, but it would certainly help.
  • You may not post replies
