Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
Thread: Update on parts I have/had
  1. #16
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,527
    New rod bolts? Thought you were supposed to change rod bearings when you took off rods due to bearing crush issues? But you change rod bolts if you disassemble?
  2. #17
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,838
    Re: Update on parts I have/had
    Northstar rod bolts are comparatively high torque items - always replace them at overhaul.
    From the GM service manual for Northstar procedures: "Powdered metal connecting rods have rod bolts which yield when torqued. If the rod bolts are loosened or removed the rod bolts must be replaced. Rod bolts that are not replaced will not torque to the correct clamp load and can lead to serious engine damage."
  3. #18
    AJxtcman's Avatar
    AJxtcman is offline Cadillac Owners Connoisseur
    Automobile(s): The Northstar Tuner
    Apr 2007
    Rock Hill SC
    48
    2,755
    The FSM stated that you needed to replace the rod bearings originaly, but they updated that information to state only if worn.
  4. #19
    Sep 2007
    Wilmington, NC
    13,969
    I talked quickly with our resident northstar guru today and he said that if theY break or if he thinks they feel "weird" coming out he replaces them. (The main bolts that is)
    Usually it s the studded one an one or more of the others.
    But often he won't need any. It all depends.
  5. #20
    AJxtcman's Avatar
    Apr 2007
    Rock Hill SC
    48
    2,755
    I have broken a few main bolts. I used to keep a few new bolts in my area at the Caddy dealer for the other techs to use because we did not stock them. Spent almost 6 years as what I would say is a Northstar Tech. Still work on Caddy's just not every day -- Chevy/Caddy dealer fits me better
    Thanks Cal Editor aka A.J.
    ASE Master Certified since 1988
    ASE L1 Certified since 1994
    ASE F1 & A9
    GM Technician since 1999
    GM World Class Technician since 2009
    CSA Inspector
  • You may not post replies
