Results 1 to 7 of 7
Thread: O5 DeVille Is That My Lifters I Hear????
    txpiedpiper is offline Cadillac Owners Member
    Automobile(s): 05 deville 97 deville
    May 2011
    Dallas Tx
    41
    15
    I have an O5 White Caddi DeVille with 157156 miles on it.. When Im accelerating I can sometimes hear my lifters reving up.. I change my own oil regularly. Im a Valvoline guy. Synthetic blend. 5w30 Its my every day transportation pretty much. So I was wondering could or should I add some of that Lucas Oil treatment next time i change my oil or is there something else i can do to quiet this?
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    DO NOT use any snake oils in your engine.
    What exactly does this noise sound like? It's essentially impossible to hear lifter noise from inside the car while accelerating.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,856
    Re: O5 DeVille Is That My Lifters I Hear????
    ........... and the engine does not have "lifters" or cam buckets as such. It uses roller cam followers with lash set by static hydraulic pistons.
    Use no snake oils. None. Nothing wrong with a name brand 5W-30 oil of whatever type you care to use.
    If you can hear "ticking" during acceleration I would first suspect an exhaust leak.
  5. #4
    Sep 2007
    Wilmington, NC
    13,969
    Possibly a crack in an exhaust manifold ... especially if it goes away once warmed up
  6. #5
    May 2011
    Dallas Tx
    41
    15
    I guess what i am hearing are the roll cams and valves. its notengine is cold and then it warmed up.. a knocking or ticking but definately the cams and valves. i dont hear the noise all the time but periodically. I hear it when the
  7. #6
    Feb 2006
    56,856
    You might want to go way up ^^^ to the black bar and study the Cadillac Technical Archive - especially the article titled "Occasional full throttle operation is good for your engine". In there you'll see a perhaps unfamiliar term: "Cold carbon rap".
  8. #7
    69
    82,281
    I hear a minor ticking out of mine when it is a real cold start. Don't forget, you have 4 cams, 32 valves and followers right up top under those cam covers. Not a lot of noise insulation there.
  • You may not post replies
