Results 1 to 12 of 12
Thread: Coolant crossover
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,527
    Question on 05+ northstar motors. Since the front of heads has the cam sprockets, does GM still use a rear mounted coolant crossover design? I am talking about the rear wheel drive cars. Like the Sts, srx?
    69
    82,278
    Re: Coolant crossover
    I don't believe so. I think the crossover and rear mounted W/P went away when the engine became longitudinally mounted.
    Aug 2007
    mpls mn
    2,527
    I think the coolant crossover has upper ports for the heads and lower ports that attach to the block? Kind of like a "K" shape. How they fit that onto the front of a rwd motor with cams/chains seems real awkward. Maybe the intake is a wet design.
  5. #4
    69
    82,278
    Quote Originally Posted by stoveguyy View Post
    It doesn't "appear" to be.
    http://www.gmpartsgiant.com/Page_Pro...X=D&SortKey=48
    http://www.gmpartsgiant.com/Page_Pro...008&SortKey=49
  6. #5
    Aug 2007
    mpls mn
    2,527
    Wow. The front of the fwd motor seems so simple now.
  7. #6
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,854
    Maybe yes, maybe no - try to get to the oil pump or timing chains..................... without removing the entire throttlebody assembly, A/C and radiator systems.
  8. #7
    Aug 2007
    mpls mn
    2,527
    I see the pic with the front cover sort of neglects to show the end of the crankshaft?
  9. #8
    Feb 2006
    56,854
    Those diagrams are from the external engine parts section. Further snooping in www.gmpartsgiant.com will open the internal parts diagram.
  10. #9
    Aug 2007
    mpls mn
    2,527
    so the front cover is hollow? or partially hollow since the waterpump mounts to the casting and coolant flows thru it and the timing chains are behind the cover and are in an oil bath.
  11. #10
    scott f's Avatar
    scott f is offline Cadillac Owners Fanatic
    Automobile(s): 2002 STS/ 1994 STS
    Oct 2010
    Oshawa, Ont. Canada
    229
    I don't see the typical "EGR" either
  12. #11
    69
    82,278
    That's because the RWD Northstar (LH2) also got "continuously variable valve timing on both intake and exhaust sides", eliminating the need for EGR.
  13. #12
    Feb 2006
    56,854
    deleted...............
  • You may not post replies
