Page 1 of 2 12 LastLast
Results 1 to 15 of 22
Thread: No acceleration... 2000 Deville
    Nov 2012
    11
    First post... Three times now out of nowhere I push the gas down leaving speed zone and nothing! Car will not kick down and accelerate. Just sounds like its bogging. 1st time thought is was cause I went thru car wash..next day fine. 2nd time snowed night before..so thought it got wet again. 3rd time..was completely dry! (thought something was getting wet..guess not!) Please any help would be super appreciated.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,842
    Re: No acceleration... 2000 Deville
    Your car has a built-in trouble code memory/scanner/reader. Many, many engine/drivetrain (P), body (B), chassis (C), and electrical systems (mostly U) and parts are monitored. Use the sticky post just above this one - "How to pull codes" - and study the proper section for your car/model/year. Get into the system and write down all codes found and whether each suffix is C or H. Now go back to the sticky and open the link with "obd2" in the address - this takes you to a Master Index which has links to definitions of all P, B, C, and U codes.
    This one is a weird situation - fine one day, poor the next does not point to a clogged catalytic converter. No kick-down might be transmission shift solenoid or line pressure problems.
    Too many scenarios - the diagnostic codes will shed some light .............. post it all in this thread - don't start another.
    Nov 2012
    11
    Thanks I will definitely start looking into that. If it helps any...I can shift the car down manually in order to accelerate. I've had problem's recently and I cleaned the tb and the iac. Then changed out the tps and everything seemed fine for a while until I got a code for the maf..so I changed that and was fine again until these couple mishaps...
    Oh yeah..the 1st night it happened it seemed like I didn't have any pressure in the radiator hose..but had heat? Next day had pressure and car was fine!
  5. #4
    69
    82,272
    Quote Originally Posted by joecaddi View Post
    Check your fuel pressure.
  6. #5
    Nov 2012
    11
    Far from a mechanic so please bare with me..just been trying to learn thru posts mostly from the two of you. So thanks thus far! So I pulled the codes from my car and tried to research the problem. No luck! Only 2 of the codes are current: AMP U1000 & IPM B0429. Car did it again today so I stopped at a shop & he recommended I check the plugs & boots. Changed only the plugs a few mths ago. Went to leave, put car in drive and the whole engine slammed! Thought tranny was shot! Started car few hours later & car went into drive normal and car was back to driving fine??? Completely lost!!!
  7. #6
    Feb 2006
    56,842
    The engine "slammed" into gear - is the idle speed at its correct 650 rpm or is it at ... 1,000+ ?
    Open the hood. Have a trusted assistant start the car in P, foot securely on the brake. Stand next to the car on the driver's side and watch the engine - have the assistant hold the brake and shift to D. How far does the engine rock toward the firewall - any more that 3/4" indicates a broken front center motor mount. If it's broken it needs to be replaced - a shop job, given your stated mechanical abilities.
    Forget the U 1000 code - voltage or data hiccup. The B 0429 is the diverter door for ventilation air to the rear seat console panel. If you didn't "clear codes", please go back and list the History codes and their definitions - there may be an intermittent clue there.
    Post #3 - Large upper radiator hose pressure is not a reliable indicator of anything other than maybe a faulty coolant reservoir pressure cap. Cold, there should be little or no pressure on the system, increasing to cap pressure as the engine warms to operating temperature - 190 - 205 degrees or so. So - cold = squishy hose; hot = hard hose (sort of squeezable - not rock hard).
    If you have the time and $$$, take the car to a GM dealer for a "transmission fluid exchange". using a pressure/vacuum machine they will completely exchange all the present fluid for the new (2006 and later) DEXRON-VI fluid. But, tell them about the odd shift problems.
    This may come down to a valve body, 1-2 / 2-3 shift solenoid, or line pressure regulator problem. Know that no transmission work on these cars is inexpensive. Hang onto your wallet.............
  8. #7
    69
    82,272
    Definitely not fuel related.
    I agree with Sub. Best case (cheapest) scenario is a cold start with RPM at 1200 and a bad front motor mount. Does it "slam" any less when the engine is warn and at normal idle RPM (650)?
  9. #8
    Manic Mechanic is offline Cadillac Owners Fanatic
    Automobile(s): 2001 DeVille
    Sep 2011
    Magnolia, TX (NW of Houston)
    47
    411
    Vaughly starting to sound like a bad torque convertor or defective valve body. These are both internal transmission problems. But who can tell from here?
    Advise: Find another shop that has a clue, it's not your plugs or boots. That's a whole other set of symptoms. Find a good shop (ask around) I recommend a Napa Autocare. We have to meet some standards.
    Vernon
  10. #9
    Nov 2012
    11
    Checked the motor mount theory..doesn't seem broke. The car is going into all gears just fine & smooth now. I wanna say my car idles around 700-750rpm. That was the only time that ever occurred. When I push the gas to floor its as if something is telling the car that its gaining normal speed (if that makes any sense), cause the car will still shift through all the gears as if I was going 55mph, but in reality I'm only goin 35mph! The whole time bogging as if something was plugged up. Again, fine one second..doing it the next! Has only occurred 5 times so far..each time car sits for a few hours or overnight and when I get in to check it out everything is fine???
    Is that "transmission fluid exchange" the same as a "flush" cause I've heard nothing but horror stories about "flushing" your transmission. Please explain a little more if you may. Any idea on the cost to do the exchange?
  11. #10
    Feb 2006
    56,842
    Long shot here - check the ground connector for the transmission wiring harness - a block bolted to the engine down low near where the wiring pigtail exits the transmission case. Actually remove the multiple wire collector box (some models have them) and check the internal connections as well as the bolt ground point.
  12. #11
    Nov 2012
    11
    Ok so here are all of my codes: (amp b1004 h, u1000 c, u1128 h, u1016 h) (ddm u1000 h, u1065 h) (dim p1531 h, u1300 h, u1301 h) (IPC b1004 h, b1327 h, b1438 h) (IPM b0429 h, b1004 h) (LRD u1301 h, u1000 h, u1065 h) (PCM p1122 h, u1065 h) (PDM u1000 h, u1065 h) (RCC b1009 h) (RIM c0658 h, u1000 h, u1065 h) (RDD u1000 h, u1065 h).... Well that is all that appeared! Hope that someone can make some sense of these.... Thanks for all the help and advice!
  13. #12
    69
    82,272
    Codes are useless without their definitions. No one has them memorized.
    Have you checked or had the CAT checked to rule out a clogged CAT?
  14. #13
    Nov 2012
    11
    Where do I get the definitions from? I haven't ruled out the catalytic converter yet but will do so asap if that is something I should check out...
  15. #14
    Feb 2006
    56,842
    From the link in the same "How to pull codes" sticky - the link with "obd2" in the address.
    http://myweb.accessus.net/~090/dtcobd2.html
  16. #15
    Nov 2012
    11
    Having trouble trying to find code definitions cause I really don't have a clue what Im looking at!!! : ( ***Question... If the car bogs while pushing on the gas in park does that mean it might not be the transmission?
  • You may not post replies
