Results 1 to 5 of 5
Thread: 2000 Deville Code P0741 & P1860
    postman2000's Avatar
    postman2000 is offline Cadillac Owners Fanatic
    Automobile(s): 1996 STS 2000 Deville
    May 2009
    292
    Well I got the dreaded duo of codes and was wondering if there is a way I can tell without much disassembly, whether just the TCC Solenoid is bad or whether I need something more substantial like a convertor or the like? I am willing to replace the solenoid if I can find someone to do it throught the side pan..I dont know if I will remove the tranny to do this..When these two codes are present together is it more than likely just the Tcc solenoid? I was reading somewhere on here about the convertor seals going bad causing the TCC to always be commanded on and thus burning it out..This car is almost at that stage of a cars life when you start wondering if repairs like this are worth it still..Thanks you guys for all your help...
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,993
    Re: 2000 Deville Code P0741 & P1860
    In your case, P0741 is caused by P1860, which is caused by a bad solenoid.
    CadillacLuke24's Avatar
    CadillacLuke24 is offline Cadillac Owners Master
    Automobile(s): Alexandra - 96 SDV --- Clyde - 15 Silverado
    Jul 2010
    Wyoming
    26
    5,748
    Youtube P1860 cadillac code...tutorial on how to do it.
  5. #4
    69
    82,262
  6. #5
    barval is offline Cadillac Owners Member
    Automobile(s): 2000 cadiilac seville sls
    Oct 2014
    6
    I see it
  • You may not post replies
