Page 1 of 2 12 LastLast
Results 1 to 15 of 21
Thread: Northstar Head/Engine removal
    sundog is offline Cadillac Owners Member
    Automobile(s): 1999 DeVille D'elegance
    Aug 2012
    Newton, Kansas
    22
    Hallo, I'm new.
    Situation:
    I have a '99 DeVille D'Elegance, a gift from an Aunt who cherished it, whose children didn't (at least not sufficiently so to invest the necessary time and money), who hoped her nephew just might. Or maybe she just thought I was gullible.
    My cousins say it runs great and everything works, it just guzzles antifreeze.
    It certainly looks good, and everything I could test without starting the car does indeed work.
    First Question: What's involved in removing the heads? My Haynes manual says special tools and procedures are involved and to let the dealer handle this job. I suspect this effort would be a waste of time, which I'm willing to gamble but not if I have to pay for it.
    Second Question: Can the engine be removed through the hood opening? Is it advisable? Is there a readily available manual that details the procedure?
    My Haynes says to drop the subframe complete with the entire driveline, then lift the car off of it. I'm not equipped for that sort of operation.
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,848
    Re: Northstar Head/Engine removal
    1) Use the Haynes for a bon fire (winter is around the corner, should burn niceley), Get an alldatadiy.com subscription.
    2)Has a block test been performed to confirm HG failure, if not, do one.
    3) Is it over heating?
    4) Do a block test, do a block test, do a block test
    5) It can be removed from the top, most folks here prefer the GM recommendation of dropping it out the bottom, But GM shows one how to yank her out the top too.
    6) Look through my started posts, i posted a GM manual step by step procedure on yanking out the top. Matter of fact, here you go:
    http://www.cadillacforums.com/forums/northstar-performance-technical-discussion/226769-northstar-removal-guide-feedback-wanted.html
    7) DO A BLOCK TEST!
    69
    82,262
    If you are going to attempt this job do yourself a BIG favor and get a FSM by Helm Inc. Ebay is your friend.
    Don't burn the Haynes manual. You'll need something to sop up the oil and coolant from the garage floor.
  5. #4
    Submariner409's Avatar
    Submariner409 is online now If it won't run, chrome it
    Feb 2006
    MD Eastern Shore, Kent Island
    56,811
    When you finally get a positive diagnosis for head gasket condition then you need to steel yourself that the best way to do a decent job of machining the block for head bolt hole inserts and replacing the head gaskets is to drop the drivetrain out the bottom of the car. All of the pointers are in here, up in the sticky posts ^^^ and in the Cadillac Tech Tips (Discussions, Item Specific) forums. You have three amateur weeks of engine work ahead of you.
    Get a real GM/Helm shop manual.
  6. #5
    vincentm's Avatar
    Aug 2010
    Kennewick WA
    38
    4,848
    It does make for great shop towels, forgot about that lol
  7. #6
    CadillacLuke24's Avatar
    CadillacLuke24 is offline Cadillac Owners Master
    Automobile(s): Alexandra - 96 SDV --- Clyde - 15 Silverado
    Jul 2010
    Wyoming
    26
    5,748
    Definitely do the block test first though. You may get REALLY lucky and have a leaking crossover, surge tank, or connection elsewhere.
  8. #7
    vincentm's Avatar
    Aug 2010
    Kennewick WA
    38
    4,848
    Quote Originally Posted by CadillacLuke24 View Post
    Leaking crossover is not lucky...have you removed one yourself with the engine still in? Holy shit, id rather have a hangover from Olde English 800...
  9. #8
    Jul 2010
    Wyoming
    26
    5,748
    Better than HGs, no?
  10. #9
    Aug 2012
    Newton, Kansas
    22
    Thanx everyone, I'm on it.
  11. #10
    Jul 2010
    Wyoming
    26
    5,748
    Good luck. Once you get everything figured out and decide what to do with it, come back here if you want to fix the HGs. There's one really good mechanic within reasonable range if you want it fixed, or we have sveral members who've done this job if you're up for the challenge.
  12. #11
    Aug 2012
    Newton, Kansas
    22
    Could you describe a "Block Test" for me? Don't worry about keeping it simple. I just want to make sure I'm not missing anything.
  13. #12
    69
    82,262
  14. #13
    Aug 2012
    Newton, Kansas
    22
    Thanx. I'll check them out as soon as I can get to them with a computer that isn't on dial-up.
  15. #14
    Feb 2006
    56,811
  16. #15
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,527
    A gift as in free? Is car nice? Good tires, body and so on? Low miles or 150k? Do u want to pay someone 2500 to fix motor right? Or sell it to someone who can fix it? I have not seen car so I can't say what it's worth.
  • You may not post replies
