Results 1 to 9 of 9
Thread: 1998 Eldorado - DexCool mix
    TheRedSharon's Avatar
    TheRedSharon is offline Cadillac Owners Member
    Automobile(s): 1985 Fleetwood Brougham (Sharon), 1998 Eldorado (Alyson)
    Dec 2010
    Greensboro, North Carolina
    26
    99
    Today I plan to change my coolant. I know that you're not supposed to "flush" the system, but one thing that concerns me is the fact that DexCool has been mixed into my system with regular green coolant. I didn't know that you weren't supposed to mix the two until after I had done it. The car had regular green coolant in it when I bought it. What should I do (if anything)?
    69
    82,273
    Re: 1998 Eldorado - DexCool mix
    I'd just drain it and refill it. What little is left shouldn't hurt anything. I did the same thing many years ago to a '96 Bonneville. Just drained and refilled it and ran it to 185K about a year and a half ago. Never had a problem. No reason to panic.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,854
    Drain the coolant and run some fresh water through the system - garden hose and some care not to get much, if any, water on engine or braking components. If you really get dedicated you can use a shop vac to pull/blow most of the residual water from the block and heater circuit. Use a 50/50 mix of whatever type coolant you like - just change it every 3 years or so. A total refill will take a couple of warmup/cooldown cycles to purge the air bubbles from the system - use the FULL COLD arrow on the top and side of the coolant reservoir - about half full, cold.
    Ooppppsss.........Ranger beat me to it.
  5. #4
    Dec 2010
    26
    99
    Cool, thanks. I drained and refilled. I put a tube of powdered Alumaseal in the upper radiator hose since the parts store didn't seems to have Bars Gold.
  6. #5
    69
    82,273
    You'd have been better off putting no additive in the cooling system.
  7. #6
    Feb 2006
    56,854
    Quote Originally Posted by TheRedSharon View Post
    Why ?? Did you have nuisance leaks before you did the coolant exchange ?? Those sealants run the risk of clogging small head gasket water passage holes as well as the (aluminum) heater core.
    The correct sealants originally installed by GM and discontinued in ?? 2002-2003 ?? were Bar's Leaks #DHC tablets or G12BP powder. 3 tablets crushed, or 1/2 tube of powder, in the bottom radiator hose.
    Please define "Bar's Gold". http://barsproducts.com/catalog/bran...ponent/cooling
  8. #7
    69
    82,273
    Sub, I think the powdered G12BP used to be called gold powder or something like that.
    EDIT:
    Here it is.
    http://www.barsleaks.net/products.html
  9. #8
    Feb 2006
    56,854
    Given the color of the tablets and powder that makes sense.............
  10. #9
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,848
  • You may not post replies
