Results 1 to 11 of 11
Thread: water pump leak after replacing pump/seal
    Jun 2005
    6
    i'm working on a friend's 97 deville 4.6 ns trying to fix a leaking water pump. i replaced the pump, pump seal, thermostat and cover gasket.
    there is still water coming out of the pump. i can crawl underneath and watch the water coming from behind the pump pulley. and it's not a slow leak, either.
    any ideas what could be causing it?
    69
    82,272
    Re: water pump leak after replacing pump/seal
    The O ring seal was not seated properly.
    Jun 2005
    6
    i took it back out, cleaned the groove, used a dab of rtv to hold the ring in place, and it's still leaking. i'm thinking maybe it's the water pump shaft seal
  5. #4
    69
    82,272
    Shaft seals don't leak that bad even when they leak after 100,000 miles of wear. If that is the case, that's one shitty pump. What brand is it? Where did you get it?
  6. #5
    Jun 2005
    6
    it's an auto zone duralast part. i don't know what else it could be if it's not the water pump itself. i've taken apart and reassembled this four times now. still can't get the leak to stop
  7. #6
    69
    82,272
    Quote Originally Posted by stockgp View Post
    All bets are off!
  8. #7
    Jun 2005
    6
    lol. i don't know what to do. i'm just spinning my wheels on this thing, and not making a dollar off of it.
  9. #8
    69
    82,272
    Considering you have gone back and double checked your work and that it is an AutoZone Don'tlast part, I'd replace it with a quality pump. ACDELCO Part # 252707 $35 at Rockauto.
  10. #9
    Jun 2005
    6
    i suggested the same thing. problem was the lady needs her car, and she didn't want to wait for one to ship in. so she bought one from auto zone. i guess i'll just have ot tell her she'll have to wait
    thanks for the input
  11. #10
    69
    82,272
    Well, she got what she paid for.
    Rockauto ships fast OR if she wants it NOW, go to a local dealer.
  12. #11
    CadillacLuke24's Avatar
    CadillacLuke24 is offline Cadillac Owners Master
    Automobile(s): Alexandra - 96 SDV --- Clyde - 15 Silverado
    Jul 2010
    Wyoming
    26
    5,748
    All bets are off!
    Built to fail, Don'tlast.
    Right Ranger?
    Go with a Delco part.
  • You may not post replies
