Results 1 to 6 of 6
Thread: 2002 Deville, White Smoke when Ideling
    Chicago Caddy is offline Cadillac Owners Member
    Automobile(s): 1996 Devile
    Jan 2012
    1
    I just got the car, its a 1996 Deville with a 02 northstar. For the most part engine sounds good. The motor has over 100k, it do use up oil. I have to add 1 qrt. Every 2months and coolent maybe 3 months. I don't see any leaks around or on motor. The car hhaven't over heated on me. When the car has been running for awhile (not after a cold start, but when the warm) I see white smoke, when idel. The smoke do smells sweet, when I look down in the block I don't see any mixing of oil and coolent. I know i have to change the o2 sensors, am doing that this week. Sometimes after I park, then get back in the car after 5 or so minutes and star it back up a cloud of white smoke comes out the tail pipes and then goes away. It's seems like it only happens when idel.
    Thank you, this is a great site! May the New Year brings happiness and wealth too all!
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,849
    Re: 2002 Deville, White Smoke when Ideling
    Are you sure your "smoke' is not simply exhaust condensation vapor (steam) due to cool/cold weather ?? Do you see other cars with steaming tailpipes on these cold mornings and in stop&go traffic ?
    If you're looking for a failing head gasket indicator, know that Northstars do not normally mix coolant and oil under that circumstance. You need to test the airspace over the coolant in the reservoir for the presence of exhaust gas products. Either rent a block test set from a large parts store or go here........www.sjdiscounttools.com/lis75500.html
    69
    82,273
    It smells sweet? Not a good sign. Do you have to add coolant occasionally?
  5. #4
    tateos's Avatar
    tateos is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 ETC (GAVE TO STEPSON 2011), 2000 DTS (RIP)
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,702
    "Sometimes after I park, then get back in the car after 5 or so minutes and star it back up a cloud of white smoke comes out the tail pipes and then goes away."
    Sounds like valve seals to me - not a common problem on these engines
  6. #5
    edb150 is offline Cadillac Owners Member
    Automobile(s): Many! I currently own & operate MIDWEST CADILLAC REPAIR
    Nov 2009
    Palatine, Illinois
    51
    92
    The white smoke after you drive it then park it could very well be antifreeze that has seeped into the cylinder when it was shutdown and under pressure. I have a block test your welcome to use if your not too far from Palatine? 847 878 5676
  7. #6
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,607
    I agree. Heavy white smoke on startup that smells like coolant, as well as periodic adding of coolant is evidence enough to justify a block test.
  • You may not post replies
