Results 1 to 5 of 5
Thread: PCM and engine switching
    neo126's Avatar
    neo126 is offline Cadillac Owners Member
    Automobile(s): 1994 STS, 2007 Escalade
    Apr 2009
    Washington
    I am curious to know if the pcm must be reprogrammed(taken to the dealer)or is it just the same procedure as if it had lost battery power.
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,993
    Re: PCM and engine switching
    For what? Engine replacement? Then no, it does not require PCM reprogramming.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,854
    He has a couple or more threads running on the same engine replacement - hard to keep track.
    Same car, same type/year engine, same PCM: put it all back together, do your pre-startup checks and drive it.
  5. #4
    neo126's Avatar
    Apr 2009
    Washington
    Normally I keep my posts together but this time it was a little different. I just wanted to make sure if it had to be reprogrammed or anything. Just don't want anything to get damaged.
  6. #5
    maeng9981's Avatar
    Mar 2009
    Dallas, TX
    25
    3,993
    Yeah, it won't require any adjustments. Erased settings and different values will be automatically learned by PCM while you are driving, given that you put a correct VIN matching engine.
  • You may not post replies
