Results 1 to 8 of 8
Thread: Overwrite Obd1
    94CaddyConcours's Avatar
    94CaddyConcours is offline Cadillac Owners Fanatic
    Automobile(s): 1994 CADILLAC DEVILLE CONCOURS, 350ZR
    Jul 2004
    LONG BEACH KALIFORNIA, HOUSTON
    443
    Overwrite Obd1
    When I use my OBD1 I can overwrite things on there but i dont know what the code mean.
    Also when I check the OBD on what my gas octan rating it read zero. I always use 91 octane. What could be the problem?
    -BILL SONG
    -AOL SCREEN NAME: khm3rkaliking
    Eldyfig's Avatar
    Eldyfig is offline Cadillac Owners Connoisseur
    Automobile(s): 13 Challenger RT, 11 CTS Coupe Premium, 94 Eldorado (RIP)
    Jan 2003
    Folkston, GA
    1,306
    Re: Overwrite Obd1
    The octane rating doesn't work on mine either. I have read somewhere that some OBDI cars aren't equipped with that capability
    Feb 2004
    Staten Island, NY
    577
    Re: Overwrite Obd1
    On my 94' STS gas octan read zero too.
    I believe, when they designed PCM, they designed it for years ahead and not all the options now are used.
  5. #4
    Mar 2004
    Florida
    37
    599
    Re: Overwrite Obd1
    ive got the sensor in my 1993 STS and it works
  6. #5
    growe3's Avatar
    growe3 is offline Cadillac Owners Enthusiast
    Automobile(s): 1993 STS and 2004 DTS
    Oct 2003
    Cameron Park, CA
    564
    Re: Overwrite Obd1
    Whether you get a readout and what the value is, are dependent on several things, one of which is the horsepower rating. If you have the LD8 (270) HP engine it will always read 0 (zero). See attached image for better explanation.
    -George
  7. #6
    Feb 2004
    Staten Island, NY
    577
    Re: Overwrite Obd1
    I've got 295hp engine on 94' STS with Z-rated tires (if it's depends of it some how) and it still reads 0. I think I should check some settings after I changed PCM. It has same service number like my old one, but that PCM has been pull out from Deville.
  8. #7
    Eldyfig's Avatar
    Jan 2003
    Folkston, GA
    1,306
    Re: Overwrite Obd1
    Thank you. Good info.
  9. #8
    JSMeloche is offline Cadillac Owners Fanatic
    Automobile(s): 2005 SRX V6 AWD
    Mar 2004
    429
    Re: Overwrite Obd1
    where did you found what the outputs mean?!? i have a GM manual and it doest say anything about the meaning of all the outputs.
  • You may not post replies
