Results 1 to 2 of 2
Thread: radiator coolant
    Apr 2004
    hampton, virginia
    31
    radiator coolant
    i'm losing alot of coolant whenever i run my ac. not seeing any leaks but if run my ac, i'm refilling every fews days or so.
    69
    82,272
    Re: radiator coolant
    Are your cooling fans on when the A/C is turned on? Maybe overheating and blowing out the overflow. That's about the only correlation I can think of.
  • You may not post replies
