Results 1 to 7 of 7
Thread: Flywheel holding tool
    ternstes is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS V, 2007 SRX V8, 2005 CTS 3.6L, 2000 STS, 1999 STS
    Nov 2008
    SW Ohio
    36
    393
    I am preparing to undertake a headgasket job on a 1997 STS, and I am wondering about the flywheel tool J-39411 versus EN-46326
    It looks like the EN-46326 is for the more recent year N*, but I am wondering if it would work on a 97 N*
    I cannot find a cheap deal for the J-39411 but I did find the other for cheap.
    Any thoughts?
    I am sure I will have many more questions later, but threads in here have provided a lot of information already. I plan on using Jake's studs once I get the engine out.
    tateos's Avatar
    tateos is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 ETC (GAVE TO STEPSON 2011), 2000 DTS (RIP)
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,702
    Re: Flywheel holding tool
    I put a long bolt through the starter flange hole and threaded it into a flywheel and torque converter bolt hole. Put a little piece of rag between the bolt shaft and the starter flange hole...I bent the bolt a little when removing the crankshaft bolt, but it didn't cost me anything and it worked.
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,527
    i have seen 3. bottom of motor when motor/trans are still in car. #2 is where starter goes. #3 is on flexplate end of motor when it is on engine stand. who knew there were 3 to choose from. might even be more. only $25 or so. thats pretty cheap.
  5. #4
    Nov 2008
    SW Ohio
    36
    393
    tateos,
    thanks for the response, but can you do that without separating the trans from the engine?
    stoveguyy,
    do you have a link or description of what you are talking about for $25? I found the EN-46326 tool for $50, and I may have the opportunity to work on another N* if my first project does not turn me off to the ordeal.
  6. #5
    jimsbox is offline Cadillac Owners Enthusiast
    Automobile(s): 2000 DHS
    Apr 2005
    Kansas City
    63
    535
    I don't know what the model number of mine is but it is the one tha you bolt in where the starter is and it worked like a charm, less than $40.00.
  7. #6
    tateos's Avatar
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,702
    Quote Originally Posted by ternstes View Post
    tateos,
    Of course - you pretty much HAVE to do it that way
  8. #7
    Aug 2007
    mpls mn
    2,527
    44214 is on ebay. $29 with free shipping. used when motor is in car. mounted on bottom of motor. you need it to tighten balancer bolt. do it before motor is taken out or after its put back in car.
  • You may not post replies
