Page 1 of 4 1234 LastLast
Results 1 to 15 of 46
Thread: 99 STS engine reinstallation question/problems
    kobrien8 is offline Cadillac Owners Fanatic
    Automobile(s): 2003 SLS 2009 CTS Premuim 2009 SRX Sport
    Mar 2010
    Columbus Ohio
    39
    108
    Over the past two weeks I have removed the cradle and had the block studed and lower half sealed. The engine is back in the car and starts, runs rough with 15% throttle, then dies when returned to idle. I keep getting P1010-mass or volume air flow circuit range/performance. The mass air sensor was working fine before I pulled the engine so I am not sure that just replacing the sensor will do the trick, although there isn't really anything upstream that would affect the mass air sensor. Right? Also, will having the gel from the spark plug wire set on the plug electrodes have any negative effects? Thanks!
    PS I am new here!
    69
    82,284
    Re: 99 STS engine reinstallation question/problems
    Where is the MAF sensor on your engine? One the TB or upstream in the duct?
    Mar 2010
    Columbus Ohio
    39
    108
    It is in the duct I am almost certain. I am going to double check
  5. #4
    Sep 2003
    Metro ATL
    4,854
    Quote Originally Posted by kobrien8 View Post
    ....I keep getting P1010-mass or volume air flow circuit range/performance.
    P1010 is not a valid code. You read it wrong or typed it wrong.
  6. #5
    Mar 2010
    Columbus Ohio
    39
    108
    Sorry! P0101. That's what I get for doing this via smart phone in the middle of nowhere!
  7. #6
    69
    82,284
    If it's in the duct, be sure you don't have a leak behind it. Check the clamp at the TB.
  8. #7
    Mar 2010
    Columbus Ohio
    39
    108
    The MAF is definitely in the duct. Also, if this helps, my freeze frame data for the MAF is 3.072 lb/min
  9. #8
    Sep 2003
    Metro ATL
    4,854
    P0101 - Mass Air Flow (MAF) Sensor Performance
    Your MAF is that 2.5" section of rigid intake air plumbing immediately upstream of the throttle body. Triple check the wire harness integrity and security / cleanliness to the 3 pin connector on the firewall surface of the MAF.
    Maybe your Smart phone isn't??
    Someone give me clue why this Seville question was arbitrarily moved to the Northstar section. Please.
  10. #9
    Mar 2010
    Columbus Ohio
    39
    108
    I wondered that myself about the question being moved but since I am new here I Just figured that I didn't use the right question asking protocol. Everything looks good as far as wiring and connections go. Should I Just spend the $100 and buy a new sensor? Is this what is causing the rough running?
  11. #10
    Sep 2003
    Metro ATL
    4,854
    .....Should I Just spend the $100 and buy a new sensor?
    That would be your call! If there is any possibility your MAF was exposed to nasty fluids or physical damage during the cradle R & R, MAF replacement "might be" your solution.
    Most likely, at this point.
    Sorry to be so wishy-washy, but your model of MAF is a "delicate" part. My background always points me to wiring as the first failure possibilty to eliminate.
  12. #11
    Mar 2010
    Columbus Ohio
    39
    108
    Thanks for the help! I am also curious as to if the gel in the plug wire pack was applied to the plug electrodes would cause rough running as well? My assistant (buddy) informed me that he put the gel on the electrodes thinking it was to make a better connection. Guess a new maf sensor is in my future!
  13. #12
    98eldo32v's Avatar
    98eldo32v is offline Cadillac Owners Connoisseur
    Automobile(s): 98 eldo/KD54 w/N37,T96,QA1,D55,DS3,U1Z. U3R next
    Apr 2010
    51
    2,125
    I'd check the wires again before buying another unit. You'd be surprised how one wire might wiggle out of the connector and "look" like it's making contact and it really isn't. I had a problem with an egr valve code, bought a valve and all only to find out when i went to install it, one of the wires came out of the connector.....
  14. #13
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,868
    Are you saying that someone put dielectric silicone ignition grease on the spark plug tips ???
    That stuff is for plug and coil boots and the seal rings on electrical connectors: It's an insulator !!!
    If this is all about the 1999 as indicated in the thread title, then your MAF is bolted directly to the throttlebody and the IAT in down by the filter box. If it's the 2003 then the MAF is in the flex intake duct and the IAT is incorporated in the MAF.....
    Early MAF..................................2000+ MAF..................... correct plug wiring
  15. #14
    69
    82,284
    Because it was strictly an engine (Northstar) question and seemed more appropriate here. I can move it back if everyone thinks it belongs in the Seville section.
  16. #15
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,527
    were plugs original or new? a leaky headgasket will/can foul up plugs. maybe try a new set. your assistant applied gel to the tips? did you see him do it? what else did he do on this job while your back was turned?
  • You may not post replies
