Results 1 to 12 of 12
Thread: 1999 Deville wont start after engine swap?
    aac123 is offline Cadillac Owners Fanatic
    Automobile(s): 2001 Deville DTS
    Oct 2008
    102
    Hello, i swapped a blown 1999 engine with a norms 1999 engine, both devilles.
    got all hooked up and it cranks all day strong but wont fire up just cranks...
    Things I have checked...
    Fuel pump on and running
    Fuel coming out of service port strong
    relays all electrical
    triple checked all grounds, fuses, relays and all electrical
    wires and plugs triple checked
    2 diff new batterys
    If you got any ideas thanks alot. If I figure it out Ill post back...
    Oct 2008
    102
    Re: 1999 Deville wont start after engine swap?
    Could it be a security thing not letting the injectors work???
    I took the donor cars computer under the air box, the brake computer, and the one under glove box.
    Do I need to swap something on the steering wheel or cluster????
    Thanks
    69
    82,272
    Are you using the donors key?
  5. #4
    Oct 2008
    102
    no im not, do i need to do one of the following
    A. Switch donor ignition lock
    B. Put original computers back on instead of donors?
  6. #5
    69
    82,272
    I think so. The security system is reading the wrong key code. Why did you swap PCM's?
    OR I think you can reprogram your key. Might try this first.
    http://www.cadillacforums.com/forums...-pk3-keys.html
  7. #6
    Oct 2008
    102
    I just left everything plugged up on the wiring harness, unhooked from under glove box and fuse block then laid pcm on top of engine when i dropped cradle.
    I think i need to put all original computers back in. Ill let you know tomorrow.
    Thanks alot
  8. #7
    tateos's Avatar
    tateos is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 ETC (GAVE TO STEPSON 2011), 2000 DTS (RIP)
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,702
    Yup - Ranger has you on the right track - the key does match up go with that PCM. For a test, you can try bypassing the VATS system by disconnecting the (yellow?) wire under the steering column.
  9. #8
    69
    82,272
    Tateos, he has a '99. Does that still have VATS? I thought it may have the newer PASSKEY.
  10. #9
    Keep your car's PCM and you don't need to change the lock cylinder. Make sure all four igintion module plugs are plugged into the ignition control module.
  11. #10
    Oct 2008
    102
    Thanks alot guys this morning I switched the pcm and the one under the glove box. Boom it started right up. Amazing they program the car to do everything but let the fuel injectors to prevent starting.
    So how would I convert the mileage of donor engine into the blown engine body? Do I need to swap cluster, ignition lock, and all computers?
    This was my original intent, to switch the mileage...
  12. #11
    69
    82,272
    I forget if the mileage is stored in the PCM or the DIC, but be advised I think that is illegal. I think the mileage is supposed to stay with the car, not the engine.
  13. #12
    tateos's Avatar
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,702
    Oh - sorry - you're probably right, Ranger
    Richard Moore
  • You may not post replies
