Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Thread: Oil level sensor & alternator terminal hookup
    Pete315 is offline Cadillac Owners Fanatic
    Automobile(s): 95 Eldorado
    Feb 2009
    305
    before I break it, how do you disconnect the wire from the sensor? there is no plug on end of sensor. looks like wires go directly into sensor. I followed the wire on the other end and there is no plug also.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,804
    Re: oil level sensor
    The oil level sensor has a 2-pin plug connector in the end of the hex head. There's a lock tab on the side of the connector body - in the hex head.
    STSS is offline Cadillac Owners Enthusiast
    Automobile(s): '03 STS 122K, '01 STS 161K - 3/3/11
    Apr 2008
    Grafton, Ohio
    32
    671
    There is a plug on the sensor end... the "leg" you have to bend out to remove it is further down inside the end of the sensor. Try to look into the end of the sensor with a flashlight.
    DO NOT JUST PULL, YOU WILL BREAK THE END OF THE SENSOR... ask me how I know.
  5. #4
    Feb 2009
    305
    thanks for the info. got it off.
  6. #5
    tateos's Avatar
    tateos is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 ETC (GAVE TO STEPSON 2011), 2000 DTS (RIP)
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,702
    Quote Originally Posted by STSS View Post
    I like that part - "ask me how I know" - sounds like me a lot of the time! LOL
  7. #6
    barrylee is offline Cadillac Owners Member
    Automobile(s): 1995 Cadillac Seville SLS
    Feb 2012
    Bentonville, AR
    87
    i pulledvthat wire out apart by accident. now i need to know which wire goes on which side of the plug?
  8. #7
    Feb 2006
    56,804
    Makes no difference - it's a magnetic "on/off" switch.
    Wiring diagrams and connector pinouts in your car subscription to www.alldatadiy.com
  9. #8
    Feb 2012
    Bentonville, AR
    87
    i have the fsm finally got the thing back together, still needvto get the serp belt on and put the freshly charged battery in. is there any use or benefit to hooking up the F pin of the alt ? the salvaged alt i got with the harness and it has not only the L but also the F dont know but can i benefit from it some how? what is it?
  10. #9
    Feb 2012
    Bentonville, AR
    87
    oh and thank you for the help i appreciate it. i still have a lot to learn.
  11. #10
    Feb 2006
    56,804
    The alternator F terminal is the Field excitation voltage - that's literally what turns the alternator "ON", and also is a part of the electrical voltage circuit that determines alternator output.
    The L terminal is the old "Light" circuit - the red dashboard idiot light - in your case, the check charging circuit signal.
    You can find various alternator wiring diagrams in the Balmar site - www.balmar.net - look at the various voltage regulator wiring diagrams. You might also try to Google something like "automotive voltage regulator wiring diagrams" or "automotive alternator wiring diagrams".
  12. #11
    Feb 2012
    Bentonville, AR
    87
    Quote Originally Posted by Submariner409
    the diagrams im seeing show L turns on input. thats all me other one had, but this alt has that L and so do i just leave off the F wire?
  13. #12
    Feb 2006
    56,804
    I don't have a '95 charging circuit diagram, so I won't guess at your terminal lineup.
  14. #13
    Feb 2012
    Bentonville, AR
    87
    why not i am guessing...i guess ill thumb through the fsm for a while. nthanks.
  15. #14
    Feb 2012
    Bentonville, AR
    87
    Quote Originally Posted by barrylee
    i guess what im asking is where do i run the sense wire to, the other alt didnt have one
  16. #15
    Feb 2012
    Bentonville, AR
    87
    battery? run a wire from red batt to this pin on alt?
  • You may not post replies
