Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Thread: N* easiest cadillac engine to work on
    cadi509's Avatar
    cadi509 is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS V Tango int
    Jan 2010
    Yakima, Wa
    28
    2,337
    I bought a 99 seville sts about 6 months ago, and since then I've cleaned the TB, changed the plugs and wires (AC delco no worries), added a K&N air filter, replaced front bose speakers, and replaced the starter, anyways I think this is the easiest cadillac I've ever worked on my previous cadis were a 93 deville 4.9 and a 84 devile 4.1, both engines were much more difficult to work on especially the water pump on the 4.9, idk why so I've heard so many people complain about working on the northstar. Oh and I don't know if there's anyone on here that lives in washington state around yakima but if you do I am willing to help you work on your cadillac, just PM me.
    FriarDDMC is offline Cadillac Owners Member
    Automobile(s): XLR
    Jan 2010
    1
    Re: N* easiest cadillac engine to work on
    .. well, I'm glad someone thinks the N* is easy to work on. I have just bought a 2005 XLR, and not knowing much about the engine, I have been reading other e/mails to get info. All I seem to read is about the horrors of Dex-Cool on aluminum engines, poor power compared to Corvettes and so on. I have had the XLR 3 months and I think it is great. I like the mass use of exotic metals such as aluminum where ever possible and an engine with 4 cams does not bother me. The XLR has a great pedigree with association with Lotus and Daimler Benz etc etc. I am used to doing my own maintenance on vehicles such as oil/filter changes, brake pad changes, rad flushing, even steering alignments. So I'll be needing a contact like you to help out. Thanks,...
    cadi509's Avatar
    Jan 2010
    Yakima, Wa
    28
    2,337
    I'm a guy that's constantly under the hood messing with something, these engines do require a lot of TLC and I probably treat my cadis nicier than some people do their kids its sad but its my passion, guess when you have to work hard to get nice things you appreciate them a little more.
  5. #4
    69
    82,284
    It all depends on what you are doing. Some things are easier, others are not.
  6. #5
    cadi509's Avatar
    Jan 2010
    Yakima, Wa
    28
    2,337
    ^^Well ya I mean like maintence and replacing parts, I'm sure its not easy to pull the engine or tranny buts that's a job no matter what the car.
  7. #6
    cl1986's Avatar
    cl1986 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 Eldorado, 94 SLS got crushed
    Jun 2003
    South Dakota
    38
    1,485
    LOL, try doing a headgasket, then see how your attitude is LOL
    or try replacing brake lines that no one sells parts for or even lines with the correct ends on them. What fun that is, after about $80 in just adapter fitting i finally got my brakes fixed on my sls, i went all over town looking for a 11mm bubble flare, no such thing around here.
    I did notice that the 94 has the easiest heater core of any vehicle i believe, pull the glove box and its right there!!
  8. #7
    Sevillian273's Avatar
    Sevillian273 is offline Cadillac Owners Connoisseur
    Automobile(s): 69 Thunderbird | 90 Seville | 89 Marquis | 72 Torino
    Oct 2008
    Palm Bay, FL
    2,024
    I'd have to agree with Ranger on this one.... I dont own a N* but I do read the tech archive often. Two things come to mind: Alternators and spark plugs. Alt swap on 4.9 is a piece of cake. N* not so much.... Plugs on a 4.9? PITFA.
  9. #8
    ponyboyt is offline Cadillac Owners Enthusiast
    Automobile(s): 97, 97, RIP 98, 99 STS with Jakes studs
    Apr 2009
    Ontario, Canada
    40
    718
    it only hurts the first time.
    i've done about 7 alternators, and a few starters. All of em were a B*... the first time but after that its all cake and icing. Had my entire air ride system apart 3 times now. All easy to do. Well, when you figure i can do most of those things in 1.10th the time it took me the first time, ya, its all easy now.
  10. #9
    cadi509's Avatar
    Jan 2010
    Yakima, Wa
    28
    2,337
    Hey I'm just sayin I don't think its so bad as most plp say it is I would rather do 5 starters on a northstar that one on a 4.9, I had a lot of consistant problems with my 93 deville which led me to sell it fast, but now that I bought a 99 sts I kind of wish I would have bought a 03 sts instead, I'm gonna be doing a 2 din dvd install here soon so we'll see how that goes?
  11. #10
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,868
    Don't forget that the original head unit is part of the serial data bus and theft system. There are tricks which need to be done to insure that the car will even start after your install.................
    If the original unit is a Bose, I think you have to change all the speakers and amps, too. Individual Bose amps drive individual Bose low impedance speakers.
  12. #11
    cl1986's Avatar
    Jun 2003
    South Dakota
    38
    1,485
    Quote Originally Posted by submariner409 View Post
    wrong topic reply?
  13. #12
    Feb 2006
    56,868
    [/quote] I'm gonna be doing a 2 din dvd install here soon so we'll see how that goes?[/quote] Post #9, end of sentence.
    PPPPPP - Prior Planning Prevents Piss Poor Performance.
  14. #13
    cadi509's Avatar
    Jan 2010
    Yakima, Wa
    28
    2,337
    Ya I've been reading posts and other such things for about 4months, I got a gmos-06 tested it with a cheap cd player for a day (no problems) all the chimes worked no codes, and if I have to I will relocate the HU in the trunk, this isn't my first stereo install, I'm only changing the HU unit out cause I'm going to upgrade and I don't wanna do a newer navigation unit, stock units are not the best, I'm getting a pioneer avh-p4100dvd next week so you'll be seeing my install "how to" with video and pics soon.
  15. #14
    eyekandyboats.inc's Avatar
    eyekandyboats.inc is offline Cadillac Owners Connoisseur
    Automobile(s): 2001 DTS(140K), 2000 ETC(284K), 1990 allante( 80K)
    Mar 2007
    Tottenham, Ontario,Canada
    1,914
    cadi509. its funny you would say your installing that Pioneer headunit. because 2 weeks ago i installed that EXACT unit in a GMC jimmy with bose.
    the install was stright forward however it did not match up properly, but its okay because i work with all plastics so i made my own mounts and filler piece. however. which brings me to my point.
    I dont think you will be all happy with that headunit! its sounds great in his jimmy But...... my stock bose navi is the superior hedunit. in Hi tones it is far better along with the Deep bass notes. He has a 10 in rockford fosgate in his trunk and it pounds a bit more then my stock Bose dual voice coil. However it doesnt have nearly the clarity.
    I would honestly look into something other then that headunit. from my personal experiences
  16. #15
    cadi509's Avatar
    Jan 2010
    Yakima, Wa
    28
    2,337
    Hm idk we'll see, I've had this planned for a while and when got the gmos-06 I hooked it up with an ok panasonic cd player and it sounded way better than the stock unit, but I do know that a lot of indash dvd units don't have as good sounding quality as a nice cdplayer cause the company focus' more on the features of the unit than the sound itself
  • You may not post replies
