Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Thread: Coolant Change Help
    midnightrider is offline Cadillac Owners Member
    Automobile(s): Cadillac Eldorado
    Aug 2009
    31
    Coolant Change Help
    Hello everyone,
    Iíve done the searches and I will follow the proper procedure on replacing my coolant. This will be simply be a drain and change along with the 6 GM tablets. Not a complete flush. My question is how much coolant will I need to replace on a drain and change only (2000 Eldorado ECT)? I know how much the Northstar will hold on a complete flush but Iím not sure how much Iíll need this time. I know it can very but I want to have the mimium amout so I know how much to buy.
    Thanks!
    69
    82,286
    Re: Coolant Change Help
    Buy one gallon of coolant and one gallon of distilled water. Pre mix it and you'll have some leftover.
    Aug 2009
    31
    Hey Ranger, so I should not buy the 50/50 pre mixed?
  5. #4
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,874
    Why spend over twice as much for what you can do on a workbench in 3 minutes??
    You get a gallon of DEX-COOL and a gallon of distilled water from the supermarket (dirt cheap). Use a 2-quart pitcher and pour half the water into it. Pour half the DEX-cool into the water jug. Pour the water in the pitcher into the half-empty DEX-COOL jug. BINGO !!! 2 gallons of mixed coolant (and the pitcher is still clean).
    3 tablets, not 6.
  6. #5
    Aug 2009
    31
    Quote Originally Posted by submariner409 View Post
    3 tablets, not 6.
    Genius!
    I thought I read to use 6 tablets to be even safer??? No?
  7. #6
    69
    82,286
    Personally I would not use any of those things any more. They just clog heater cores and purge lines. Even GM quit using them.
  8. #7
    Aug 2009
    31
    So would everyone agree with Ranger and NOT use the tablets?
  9. #8
    Feb 2006
    56,874
    If you now have no weeps or leaks, why chance clogging up a heater core or purge line ???
  10. #9
    Aug 2009
    31
    Nope, no leaks so I will not be using the tablets. Thanks everyone for the advise.
  11. #10
    tateos's Avatar
    tateos is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 ETC (GAVE TO STEPSON 2011), 2000 DTS (RIP)
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,702
    Personally, I don't think 3, or even 6, tablets ever clogged anything - but if anything, maybe it would be the small purge line orifice on the '99 and older design engines. I did notice a distinct dried, brown coating on the outside of the cylinders and surrounding water jackets on my '97 when I did my HG, which I lightly wire brushed off with a long, small diameter, brass wire brush.
  12. #11
    codewize's Avatar
    codewize is offline Cadillac Owners Master
    Automobile(s): 91 Brougham d'Elegance / 95 Fleetwood Broug/ 01 DTS / 11 CTS Lux
    Apr 2005
    Upstate NY
    50
    6,920
    3 tablets per GM in the lower hose. I actually put mine in the upper hose because it was easier. You'll get about 6 quarts out so you'll need to put 6 quarts back.
    Don't waste the money on pre-mixed coolant. You get half the coolant for more money. Buy a gallon of DEX and a gallon of distilled water. Make a 50 / 50 mix and you'll have 2 quarts left over for topping off later.
    Ownership:
    91 Brougham d'Elegance 350
    95 Fleetwood Brougham
    01 Custom Deville DTS
    2011 CTS4 Luxury
    Memberships:
    National and regional Cadillac & LaSalle Club
    Proud Volunteer - Northstar Tuning Project
    Guinness World Records - Largest Cadillac Parade
  13. #12
    Aug 2009
    31
    Quote Originally Posted by codewize View Post
    Codewize, did you crush your tablets first or put them in whole?
  14. #13
    Feb 2006
    56,874
    Crushed.
  15. #14
    69
    82,286
    It is actually easier to put them in uncrushed. They will dissolve pretty quick and the water pump impeller will take care of the rest. The only reason for crushing them is on the 4.1, 4.5 and 4.9 they go in the radiator and due to the oil cooler line inside the side tank there is not enough room to get more than 2 in there whole.
  16. #15
    codewize's Avatar
    Apr 2005
    Upstate NY
    50
    6,920
    I did not crush them. I put 3 whole tablets in the engine side if the upper hose.
    This was about 3 years ago. However, I recently had a very minor coolant leak. I even noticed a few drops of coolant on the splash pan while changing the oil.
    I took it into the dealer prepared to have the crossover gaskets done but they told me it wasn't leaking there. They did a leak-down test and found nothing was leaking. Odd, since I was loosing coolant and we all agreed there was a drip.
    They added 3 more tablets to the lower hose. So far so good.
    Quote Originally Posted by midnightrider View Post
    Ownership:
    2011 CTS4 Luxury
    Memberships:
  • You may not post replies
