| Re: Air conditioning compressor clutch bearing Ranger is correct - that's exactly what I was told had to be done to ensure the best and most durable results. Maybe you should look into having the system evacuated again and pull the orifice tube and see if it has caught any more trash; or ideally, you should evacuate and flush the system, replace the condenser, and also install another new accumulator. I was told that the reason to replace the condenser is that the tubes are so small you can never be sure they are all clear after flushing. |
