| Northstar Performance and Technical Discussion Performance discussions relating to the Northstar System (intake, exhaust, cam, etc.). | Cadillac Forums: Head Gasket Repair At Your Location!
09-13-09, 09:32 PM
|  | Owner of Northstar Performance Cadillac(s): 97,98,99 STS-97 Eldo- 01 Deville, 04 Bonneville GXP | | Join Date: Mar 2007 Location: Langton, Ontario | | | Re: Head Gasket Repair At Your Location! Just a side note, Mike, while this will keep you busier than all hell, you may have a problem when it comes to people breathing down your neck while you work. I haven't had too many problems with this, but I've had enough. There are some people with whom it works really well, working while they're around, but then there's the others, who just bombard you with questions, suggestions, etc...
I wish you the best with this one, but the tools that are required are a lot to drag around. You won't always have what you need in the back of a truck or car.
What's going to happen when you're 500 miles from home, tear an engine down and find a crack in the cylinder? The customer changes his/her mind about fixing the car, or you wind up having to remove the block, find another one, and then you'll be pulling the engine or dropping it out the bottom. What about main bearing problems (from coolant in the oil) or the results of hydro-locking (bent connecting rods on 00+, cracked cylinder walls on 93-99)- you'll have to have the ability to remove and replace the block, and have access to one. If you haven't run across these problems yet, you will. I've run into about 7 or 8 cracked blocks, 4 blocks that threw rods (2 being due to hydrolocking), bad cams & lifters, worn bearings, collapsed chain tensioners, burnt valves...
You can deal with these issues so much better in your own shop. On the bright side, if you enjoy travelling..... |
09-18-09, 12:24 AM
| | Cadillac Owners Fanatic Cadillac(s): Cadillac | | | | | Re: Head Gasket Repair At Your Location! Jake, if the car had a severe oil leak, I would agree that the engine has to be removed and I'll definitely give your method a try the next time I have a cracked block or a bad oil leak, but you have to realize I don't do any of those things you mentioned either plus:
-pulling the starter
-removing the flywheel bolts through the starter opening
-remove the transmission bracket mount bolts
-the fight of pulling the engine away from the transmission
-the fight on installation of aligning the transmission dowel pins to the engine
I realize you have this down to a science by now as I do with doing them in the car, but unless the car requires an oil pan gasket or a block re-seal, then I can't justify the extra work.
I know what you mean by persistent customers as I've been there and done that, but most of the time they are just curious about their cars and the repair in general. I also agree that there will be issues that arise from cracked blocks, etc., but I still think it's a service I could offer to people who are a little too far away from me to justify towing. I, like you, have decided to make this a main source of income so I am thinking of ways to make this a sustainable venture vs something that will last a year or so and fade away. Hopefully for the both of us, people will still care enough about their Cadillacs to keep repairing them instead of buying new as soon as problems arise.
Mike |
09-18-09, 03:01 AM
|  | Owner of Northstar Performance Cadillac(s): 97,98,99 STS-97 Eldo- 01 Deville, 04 Bonneville GXP | | Join Date: Mar 2007 Location: Langton, Ontario | | | Re: Head Gasket Repair At Your Location! The day you decide to switch completely to studs and back the HG repair with a 5 year warranty is the day you'd probably be the most sought after and respected independent Northstar tech in the USA. I know you're doing well but you should be able to see the advantages of the studs. I know the engine has to be pulled to install them but there are so many other advantages to having the engine out- the ability to change the rear main seal, do the oil seals, inspect the bottom end, easier work area, etc.
You're a bright man and a damn determined one if you're willing to do the HG's in the car. Do you want to take another giant leap? Call me someday. I can't do all the Caddys, the Northstar community needs you too. You could be pulling in well over 100k/yr if you play your cards right. On-site service is just not the way to go. Liability, travel expenses and time.... I've considered this too- I could see the world if I wanted to but I barely get time to spend with friends and family as it is. Since you made it your main source of income, make sure it stays that way.
We are in no way each other's competition considering the areas we're in so we might as well put our heads together.
Norm's inserts are in my opinion, better than time-serts but still a mistake to install. It will last, most of the time, but for how long? Considering what he's all posted on his site and ebay referring to me copying his thread patterns and saying the metalurgical properties are all wrong with the studs, I won't hold back. His design is an improvement over GM's inserts, a large one, but they're still an insert. Davz (another forum member) used his inserts and wound up coming to me for an engine. I have his old one. I wonder why.... The one I sold him works, the one he sold me failed because of those inserts. Norm doesn't repair these engines on a daily basis. He doesn't have to offer a 5 year warranty on them. I do that by choice. I sell what I use and I use what I sell - that's the difference.
Customers sometimes are nervous when they come to pick up their car that the engine will overheat again. So, I do what anyone would, who believes in their work. I take them for a ride in their own car, and with their permission, open it up to 90MPH (WOT) - the temp stays on the 1/2 mark the whole time. If they're not convinced I give it a couple more runs like this. Then a smile comes across their face, followed by the sentence "Man I missed being able to do that!" I stand behind my work strongly.
For the record, the 5/8x11 thread system has probably been around since the 19th century sometime. I didn't even know about his inserts when I first designed the studs. It just seemed like the best diameter and coarseness to go with, all things considered. There's just enough meat in the block to safely rethread the holes to that size.
Get yourself a good shop set up. You can do it. Become a part of Northstar Performance. Let us work together. You obviously have the will and the patience and the determination. Do you know how badly I need a contact in the USA to refer people to? Do you realize that you're a lot like me- you took the time to figure out a way to make it work- to develop a routine process to get the work done efficiently.
Change your method to studs, back it with a 5 year warranty against HG failure, and work with me. Not for me. WITH me.
Either way, best of luck to you with what ever you decide. |
09-18-09, 03:53 PM
| | Cadillac Owners Member Cadillac(s): 2002 Cadillac Seville STS | | Join Date: Aug 2009 Age: 23 | | | Re: Head Gasket Repair At Your Location! Intresting to see such deep differences in philosophies... I think both of you guys are extremely talented, creative and confident at what you do...
However... Mike, you have a formula that does work. period. I have to thank you for doing it the way you do because it gave me the confidence to have my tech attempt it that way as well. Ultimately it is a more cost effective way to go... and if everything else down there looks good... why mess with it anyhow. Plus... mike can do somebodies car in Miami... with some hot girl in a bikini asking him what a camshaft is...
Hey.. those studs sound incredible no doubt... but when you stop and look at the OEM headbolts... i'm sure norms or studs coupled with mls gaskets should hold up over 100 times better that the original setup. A good running N* is a good running N* with studs, norms or oem headbolts that hold...
I'm one that appreciates diversity not monopolies. Kinda like my portfolio... so i encourage you both to do what you do and be the best at it... because your traveling the road less traveled... who knows what either of you will learn down the road...
P.S. eldo i am NOT knocking your way AT ALL... im just encouraging mike cause he does some good sh!t by doing in the car... beleive me eldo you are unreplaceable (as long as you finish them damn motor mounts lol)... |
09-18-09, 05:43 PM
| | Cadillac Owners Fanatic Cadillac(s): Cadillac | | | | | Re: Head Gasket Repair At Your Location! I totally agree with you Jay, but I have NO objections to working with Jake on these repairs. If he needs someone in this area to install stud kits, there's no reason for me to turn away someone needing help. I can't say that I will abandon my repair method, as it works very well for me, but I would rather make a friend than an enemy, so I am completely open to installing studs for customers that want that method over inserts. Ultimately it's what the customer wants, plus I will have to work with Jake to be sure we can negotiate pricing, etc. since his studs are significantly more than Norm's inserts. I honestly believe that either method is a permanent, long term solution to this problem or I wouldn't be investing so much time and effort into it, and not to mention that sweet girl in Miami deserves a quality head job like we all do right?
Jake, I agree we both are a lot alike. I'll be out of town this weekend, but e-mail me @ mikelawson@ctky.com and we can discuss our options.
Thanks, Mike. |
09-18-09, 07:09 PM
| | Cadillac Owners Connoisseur Cadillac(s): Cadillac 78 Seville, 78 Coupe de Ville, 92 Sedan de Ville | | Join Date: Feb 2007 Location: Maine Age: 48 | | | Re: Head Gasket Repair At Your Location! I thought I read a hundred times it was a waste of time to remove a Northstar from the top; they just had to be removed from the bottom with the whole cradle. Now I see that Jake? (Northstar Performance) takes them out the top in less than 3 hours!!! And Mike fixes headgaskets with Norm's inserts with the engine in the car!! This is more my cup of tea and I'm starting to see dollar signs myself. I'll have to be on the lookout for some cheap caddies with blown headgaskets to experiment with. Keep up the good work guys. |
09-19-09, 12:24 AM
|  | Owner of Northstar Performance Cadillac(s): 97,98,99 STS-97 Eldo- 01 Deville, 04 Bonneville GXP | | Join Date: Mar 2007 Location: Langton, Ontario | | | Re: Head Gasket Repair At Your Location! The bottom line is that it is almost a sin to get rid of these beautiful cars because of the HG failures. Myself, Mike, and a some others will help make sure that these Northstars keep running for a long time to come. |
09-19-09, 12:29 AM
|  | Owner of Northstar Performance Cadillac(s): 97,98,99 STS-97 Eldo- 01 Deville, 04 Bonneville GXP | | Join Date: Mar 2007 Location: Langton, Ontario | | | Re: Head Gasket Repair At Your Location! And when the rest of the car gives out, the engines will still be in good enough condition to power your hot rods, Fieros, garden tractors, excavating equipment, generators, water pumps.... shall I go on?
I would say motor boats too, but that's where the 455 Olds motors come in. Right Sub?  |
09-19-09, 12:59 AM
|  | Cadillac Owners Fanatic Cadillac(s): 1994 CADILLAC DEVILLE CONCOURS | | Join Date: Jul 2004 Location: LONG BEACH KALIFORNIA | | | Re: Head Gasket Repair At Your Location! Quote:
Originally Posted by 97EldoCoupe The bottom line is that it is almost a sin to get rid of these beautiful cars because of the HG failures. Myself, Mike, and a some others will help make sure that these Northstars keep running for a long time to come. | Long live the Northstar!!!!!
Hey Jake how do you pull an engine out in 3 hours? Care to share tip or write up for other member who are pulling the engine out from the TOP. You should have a high performance engine by now and swap it out once every other year for emission testing? |
09-19-09, 07:53 AM
|  | Owner of Northstar Performance Cadillac(s): 97,98,99 STS-97 Eldo- 01 Deville, 04 Bonneville GXP | | Join Date: Mar 2007 Location: Langton, Ontario | | | Re: Head Gasket Repair At Your Location! Now that we have a base line to work with - 14.95 sec. 1/4 ET - the performance engine is under way. Maybe I'll do a write up soon- it's a tricky process and depending on the year, a lot of stuff under the hood has to be removed to gain the clearance, but once you know the location of every nut and bolt, the wrench size, know the tools to use, it gets faster. I made some of my own tools to make life easier as well, like an engine lift bracket that gets used A LOT in my shop.
I don't know what the stock PCM will all allow for modifications, but the plan is to work around the PCM and do everything to the engine that seems to make a difference. |
09-21-09, 10:19 PM
| | Cadillac Owners Member Cadillac(s): Deville | | Join Date: Dec 2008 Age: 35 | | | Re: Head Gasket Repair At Your Location! How much would you charge to repair the head gaskets in Atlanta again? I could use your services. I'm looking for a good mechanic that can do the job right. I want to keep the car. |
09-22-09, 10:16 AM
| | Cadillac Owners Fanatic Cadillac(s): Cadillac | | | | | Re: Head Gasket Repair At Your Location! Atlanta is approximately 425 miles from my location. It would cost .60 a mile for the round trip of 850 miles or 510.00. This covers all travel related expenses including hotel stays, etc. My standard labor price is 1500.00 + parts cost which varies per vehicle, but is in the 500.00 range. I can give you a more precise esimate if you require, I just need to know the year of your Deville and how many miles are on it.
Mike |
09-22-09, 02:50 PM
| | Cadillac Owners Member Cadillac(s): 1999 Eldorado | | Join Date: Apr 2006 Location: Mass. | | | Re: Head Gasket Repair At Your Location! I can't win......Someone finally will do a headgasket repair and he's 1000 miles away. Why is there noone who will do it in New England !!!! |
09-22-09, 05:30 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: Head Gasket Repair At Your Location! Someone posted a while back about a place in Boston that he was quite happy with. |
09-22-09, 09:38 PM
| | Cadillac Owners Fanatic Cadillac(s): 1997 STS | | Join Date: Apr 2009 Location: Ontario, Canada Age: 33 | | | Re: Head Gasket Repair At Your Location! everyone always talks about HG repair. What about all the OTHER parts that these cars kill?
ABS pump
Rear air shocks
Air ride pumps
control arm bushings
im sure there is lots more.
My handy dismantling crew and I are talking about salvaging these parts off of cars that would cost $5k plus to repair (not including engine).
I see a lot around here with good pumps/shocks but completly rotted bodies and such. They had my engine out in 20 minutes. Im sure with a little more time they could have a bit of finesse and even salvage some body parts, i need some rear doors  Who would want these parts though? Who would want all these Northstars i can get my hands on?
If there were extra engines laying around, wouldn't it be feasable to SWAP bad for good instead of traveling and doing the repair? Seems to me that would be an easier job. Then its just in and out and no unscheduled hangups. Maybe charge a bit more than BASE cost but round it down from what it would cost max. | | Cadillac Discussion Tools | | |
Censor is ON | | | |
