  Follow CadillacOwners on Twitter
Go Back   Cadillac Owners Group > General Discussion > Cadillac Engine Technical Discussion > Northstar Performance and Technical Discussion
Northstar Performance and Technical Discussion Performance discussions relating to the Northstar System (intake, exhaust, cam, etc.).
Cadillac Forums: 93-99 Camshaft picture needed
Old 07-05-09, 02:17 AM
Cadillac(s): None
View 89IrocZ's Photo Album
Casino Cash: $310
Question 93-99 Camshaft picture needed
Hi, I am trying to figure out what the camshaft sensor pickup looks like on the 93-99 northstar engine for a northstar ignition project. I have done a lot of searching on the internet and have found nothing.
Anyone have a picture of the front left cylinder head with the valve covers off?
Thanks a ton.
  #2 (permalink)
Old 07-05-09, 02:59 AM
Cadillac(s): None
Casino Cash: $310
Re: 93-99 Camshaft picture needed
I guess I can't edit the post.. to clarify I am looking for a picture of the trigger wheel or what triggers the cam sensor a picture of the cam gear will probably show it. I am modifying a SBC to run on northstar ignition module.
  #3 (permalink)
Old 07-05-09, 09:26 AM
Mark C's Avatar
Cadillac Owners Enthusiast
Cadillac(s): 1997 Seville STS, 2000 Seville STS
View Mark C's Photo Album
Casino Cash: $18370
All it is, is a metal dowel about 3/8" long that sticks out of the exhaust cam gear. Its on both exhaust gears but only the one on the rear head is used. As the dowel passes the sensor it sends a pulse to the PCM/ECM.
  #4 (permalink)
Old 07-05-09, 11:32 AM
submariner409's Avatar
Casino Cash: $22654
In the diagram you can see the circle indicating the location of the cam position sensor and the small dots on the face of each of the two sprockets are the dowel of which Mark C speaks. The sensor triggers a pulse each time the cam sprocket passes 6:00 (related to the head surface), so if you can supply the proper pulse (half engine speed) you should be OK.
Somehow, find the total amount of electrical advance allowed by a coil pack-driving PCM. A Northstar only runs 32 - 34 degrees, MAX total due to the very short stroke.
  #5 (permalink)
Old 07-06-09, 12:09 AM
Krashed989's Avatar
Cadillac(s): 94 Eldorado, and a totaled z rated STS
View Krashed989's Photo Album
Casino Cash: $12508
This is the best pic I have of it. If you want I can find the original and crop a closer view.
99 eldorado, VIN: 9
  #6 (permalink)
Old 07-07-09, 03:08 AM
Cadillac(s): None
Casino Cash: $310
Awesome! Thanks guys!
  #7 (permalink)
Old 07-09-09, 12:57 AM
GizmoQ's Avatar
The Only Good Gremlin
Cadillac(s): 96 Eldorado ESC-V -- One day ;)
View GizmoQ's Photo Album
Casino Cash: $17042
Not to hijack this thread, but any of you guys got any pics/schematics/drawings/specs of the water pump pulley on the opposite side. I need to figure out how its routed and if I can pull 10 HP off it.
  #8 (permalink)
Old 07-09-09, 09:44 AM
Casino Cash: $22654
Don't forget that the water pump drive pulley turns at half engine speed (cam speed) so if you're thinking of driving a blower or something you'll need to change to a 12" pulley to get the speed back up. (and the cam bearings won't take the load, either.)
9399, camshaft, needed, picture
attach your bluetooth cell phone to onstar
cadillac key wraps
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
