Results 1 to 3 of 3
Thread: 2002 caddy deville
    drapedupDTS is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Nov 2006
    10
    2002 caddy deville
    i have a 2002 cadillac deville and for a while now i have been having a bad rough idle and the acceleration is less than perfect.... short and sweet my question is that what is the economical way to test the issue accurately and a good online store to buy the coil packs if needed... Thanks
    69
    82,284
    Re: 2002 caddy deville
    Before you buy anything do a search for plenum and check that. While you're there, clean the TB.
    Mark C's Avatar
    Mark C is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Seville STS, 2000 Seville STS
    Jul 2007
    59
    1,693
    If you had a bad coil pack chances are you would have an SES light on and a P0300 misfire code in your current DTCs. Pull your DTCs to find out what the car thinks is the issue. P0300 by itself, probably a coil pack, or plugs or plug boots, P0171 or 0174 with or without a P0300 means vacuum leak and probably a split plenum boot.
  • You may not post replies
