Go Back   Cadillac Owners Group > General Discussion > Cadillac Engine Technical Discussion > Northstar Performance and Technical Discussion
Northstar Performance and Technical Discussion Performance discussions relating to the Northstar System (intake, exhaust, cam, etc.).
Cadillac Forums: changing starter on 1998 deville--have you done it?
Old 05-25-09, 08:33 PM
View wpbrink's Photo Album
Casino Cash: $725
need to replace the starter in my 1998 cadillac deville......in reading i see its seen after you remove the intake........have any beginners done this or professionals and how hard is this job? if i don't do it would should be the normal shop time for this job? would like to do it myself but seems complicated........any advise?????
  #2 (permalink)
Old 05-25-09, 09:27 PM
View Ranger's Photo Album
Casino Cash: $24266
Re: changing starter on 1998 deville--have you done it?
Not complicated at all. Depressurise fuel rail. Disconnect fuel supply line. Disconnect injector harness (at each injector). Unbolt manifold and lift it off. Not sure what the torque settings are for reinstallation.
  #3 (permalink)
Old 05-25-09, 09:36 PM
Casino Cash: $24266
Have you checked the Tech Tips section?
http://www.cadillacforums.com/forums...7-deville.html (Starter 97 Deville)
  #4 (permalink)
Old 05-26-09, 12:15 AM
Krashed989's Avatar
Cadillac(s): 94 Eldorado, and a totaled z rated STS
View Krashed989's Photo Album
Casino Cash: $10983
Originally Posted by Ranger View Post
...Disconnect injector harness (at each injector)...
You don't even have to disconnect the wires at the injectors. All the wires come together, then go through a hole on the TB side of the intake manifold, then straight into a fat gray plug underneath the TB.
Maybe I'm just thinking about how to completely remove the intake manifold though.
  #5 (permalink)
Old 05-26-09, 12:18 AM
Casino Cash: $24266
That's easier yet.
  #6 (permalink)
Old 05-26-09, 07:27 PM
Casino Cash: $725
ranger, thanks for the link you sent me but i have a question on the torque.........in the haynes manual on the 4.6L v8 engine it says to torque the intake manifold bolts to 89 in-lbs.......but this was totally different than what that guy had stated in the link you directed me to..........i'd like to do this job myself after reading the link but what scares me is getting the correct torque......if anyone could help me with the exact torque or double check the torque settings for me i'd really appreciate it........also, in ref. to the torque how many exact bolts will i be torqueing down just so i'm on the right page? thanks guys for helping me as i really appreciate the help.....money is tight and the dealership wanted $200.00 to install the starter..........
  #7 (permalink)
Old 05-26-09, 07:34 PM
Casino Cash: $725
ok, now i'm really lost after reading about the wires at the injectors.......i don't understand any of the TB side of the intake manifold or the fat gray plug under the TB.......(whats the tb????)
You don't even have to disconnect the wires at the injectors. All the wires come together, then go through a hole on the TB side of the [COLOR=blue! important][COLOR=blue! important]intake [COLOR=blue! important]manifold[/color][/color][/color], then straight into a fat gray plug underneath the TB.
Maybe I'm just thinking about how to completely remove the [COLOR=blue! important][COLOR=blue! important]intake [COLOR=blue! important]manifold[/color][/color][/color] though.
  #8 (permalink)
Old 05-26-09, 08:05 PM
Krashed989's Avatar
Casino Cash: $10983
TB = Throttle Body
Disconnect the Fuel lines, the EGR tube, the fat gray connector in the pic, the PCV tubes, the front spark plug wires, the throttle position sensor wire, the 2 small coolant lines, the ground wire for the metal part of the fuel rail, and the MAF sensor wire. Then unbolt the manifold and it should come right off.
The intake manifold
The fat gray plug I mentioned
With the manifold off
It sounds harder than it is. I don't remember the torque specs off the top of my head so I'd have to go look.
  #9 (permalink)
Old 05-26-09, 10:10 PM
Casino Cash: $24266
89 in. lbs is correct.
89 in. lbs = 7.4 ft. lbs
  #10 (permalink)
Old 05-30-09, 12:42 AM
93eldodave's Avatar
Cadillac(s): eldorado
View 93eldodave's Photo Album
Casino Cash: $735
TB means throttle body or drivers side, and i torq the intake bolts with a 1/4 in ratchet and my hand ...snug .. i have always thought the 89in lbs where just a tad to tight and would crack the plastic... just my thought..
1998, changing, devillehave, starter
