| Re: 96 Eldo engine sputters and stalls. P0300 and P1380 Engine Misfire. If the misfires began after you replaced the plugs and wires (ACDelco #41-950 plugs and an AC wire set), check your wire hookup against these diagrams. Coil-plug wiring is critical because this is a waste spark system: two plugs fire at the same time. Google "waste spark ignition".
No fuel injector module per se; they're tripped by the PCM signals from the CKP's and CMP and the pulse duration is modified by engine operating conditions such as temperature, throttle opening, MAF, MAP, and load. |
