Results 1 to 15 of 15
Thread: Engine almost stalls
    Dadillac's Avatar
    Dadillac is offline Cadillac Owners Connoisseur
    Automobile(s): 2015 Mazda3 S GT Hatchback 2013 Kia Optima SXL
    Nov 2004
    Woodbridge NJ
    51
    2,817
    So my '02 SLS has developed an issue. At completely random times the engine will drop RPM to the point of almost stalling, and then return to normal. It will occur when the engine is cold, warm, or hot. It will occur when the car is in motion, or when standing still. It never sets a code so I am at a loss. My only guess would be possibly the battery. The battery is the original so it is at least 7 years old. The dash is showing the volts right at 14.4 so it is reading okay. I will say that the dash used to read 14.9 to 15.0 always. Is my battery biting the big one?
    Don
    69
    82,272
    Re: Engine almost stalls
    I think your battery is fine with those voltage readings. Are the CKP sensors original?
    Dadillac's Avatar
    Nov 2004
    Woodbridge NJ
    51
    2,817
    The CKP were changed out several years ago. When I was having CKP issues, it would stall very now and again. The almost stall issue I am having is happening everytime I drive the car. Thus why I was thinking a battery issue.
    Don
  5. #4
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,842
    Even if the battery was toast, the charging system is apparently providing enough voltage/amperage (14.4) to efficiently run the car.
    Your problem sounds like idle speed control, dirty throttlebody, vacuum leak, or some such engine-related bug.
    Codes ???
  6. #5
    69
    82,272
    Quote Originally Posted by submariner409 View Post
    Codes ???
    That would have been my next guess. Don't overlook the ever popular ripped plenum.
  7. #6
    Dadillac's Avatar
    Nov 2004
    Woodbridge NJ
    51
    2,817
    Codes ???
    I know very little about the sensors and what not so bear with me. If the ISC were failing, wouldn't I be getting codes? A vacuum leak should be a more steady issue, and should become more pronounced while under load. Correct? I am getting no codes when this issue arises.
    Don
  8. #7
    Dadillac's Avatar
    Nov 2004
    Woodbridge NJ
    51
    2,817
    If the plenum is ripped wouldn't that act more like a vacuum leak? And wouldn't it actually cause the RPM's to rise?
    Don
  9. #8
    69
    82,272
    It would seem that way, but I have seen many of them act very weird here. It's easy enough to test. Just spray some Brakeleen near the base of it. That is where they generally rip. Listen for an RPM increase.
  10. #9
    Dadillac's Avatar
    Nov 2004
    Woodbridge NJ
    51
    2,817
    I'll try that tomorrow while I do mt brake job. Thanks
    Don
  11. #10
    Dadillac's Avatar
    Nov 2004
    Woodbridge NJ
    51
    2,817
    Well I sprayed the plenum with brake clean and there was no idle change. So I guess I can rule that out.
    Don
  12. #11
    69
    82,272
    When was the Tb last cleaned?
  13. #12
    Dadillac's Avatar
    Nov 2004
    Woodbridge NJ
    51
    2,817
    That was about two years ago. I was actually thinking of doing a cleaning this afternoon. My almost stalling issue hasn't happened in a few days so I will wait for it to return to look further. But I guess it wouldn't hurt to clean out the throttle body.
    Don
  14. #13
    69
    82,272
    I do mine every spring Don. Probably a little more often than needed, but it makes the job a piece of cake.
  15. #14
    C0RSA1R's Avatar
    C0RSA1R is offline Cadillac Owners Connoisseur
    Automobile(s): '98 ETC Black 90k miles
    Oct 2008
    Lisle, Illinois
    31
    1,061
    I cleaned my TB and had a very noticeable performance increase. Thanks to the step-by-step instructions on this forum, it only took about 45 minutes from start to finish (including finding a proper CD to listen to while I was working).
  16. #15
    Dadillac's Avatar
    Nov 2004
    Woodbridge NJ
    51
    2,817
    I cleaned the throttle body and it wasn't too gunked up. It only took about 10 minutes. I drove the car yesterday and the almost stall occurred one time. So I am at a loss. i just wish it would throw a code. At least I would know where to look. Thanks for the tips guys. I am just gonna drive it and if it ever actually stalls hopefully a code will set that will help me.
    Don
  • You may not post replies
