Results 1 to 4 of 4
Thread: Bypass AC pump 94 Eldorado
    mcgyver is offline Cadillac Owners Member
    Automobile(s): 1994 Elderado
    Mar 2009
    1
    Exclamation Bypass AC pump 94 Eldorado
    Have a bad AC pump bearing on a 1994 Cadillac Eldorado 4.6L engine, would like to know if anyone has used a shorter serpentine belt to bypass the pump pulley. I know there's an after market bracket with pully but I don't want to tear car apart to install one. Would greatly appreciate it if anyone has any information on this subject!
    Krashed989's Avatar
    Krashed989 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 Eldorado, and a 99 ETC
    Sep 2004
    Hilo, Hawaii
    29
    3,887
    Re: Bypass AC pump 94 Eldorado
    Yup, I have a shorter belt on my engine, bypassing the a/c compressor. Hold on while I find the info on the size of belt I'm using.
    greg-sls's Avatar
    greg-sls is offline Cadillac Owners Enthusiast
    Automobile(s): 1997 SLS
    Jun 2007
    Phoenix
    550
    Bypass belt: 74.5" approx $25 (Goodyear 4060745 or AC Delco 6k739). If the 94 4.6 is the same as a 97 4.6.
  5. #4
    Krashed989's Avatar
    Sep 2004
    Hilo, Hawaii
    29
    3,887
    I have 5060755 on mine.... it's a little looser than the size mentioned above but I figure it's better for the bearings in all of the other components.
    Breakdown on the number
    50 = the brand
    60755 = length in millimeters
  • You may not post replies
