Results 1 to 9 of 9
Thread: Fuel pump removal pictures
    planocolt is offline Cadillac Owners Member
    Automobile(s): 1999 sts
    Dec 2008
    65
    OK just to let everyone see the great access panel in a 99 STS and the ease of service for a fuel sender unit.
    Nice access in the trunk:
    Herer is a picture of the lock ring: No threads!!
    Here you can see the ring about half relocked (see the slots )
    Old dirty Fuel sending unit:
    Problems with your fuel gauge, here is the problem, see the deposits and the corroded contacts:
    Note: no "Melted wires..." hmmmmmmm
    chubbyranger is offline Cadillac Owners Connoisseur
    Automobile(s): 99 Seville STS, 08 STS4 N* 1SG F55
    Apr 2007
    The Ocean State
    53
    3,516
    Re: Fuel pump removal pictures
    Did you use a lock ring tool or just pound it? I've been trying to psych myself up for this job for two years, but I suffer from fuel-a-phobia. Already bookmarked this thread. Thanks for the pix.
    Dec 2008
    65
    Quote Originally Posted by chubbyranger View Post
    Sooo easy, pb Blaster, Sit for 1 hour, BIG hammer and basically a huge Flathead screwdriver. It took some pounding AND all fuel lines were still connected. Once it pops, it's off. The bigger hammer theory worked here.
    Total replacement time (aside from the PB blaster wait time) ~1 hour (including removing the inner trunk liner).
  5. #4
    tateos's Avatar
    tateos is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 ETC (GAVE TO STEPSON 2011), 2000 DTS (RIP)
    Jul 2007
    FOUNTAIN HILLS, AZ
    60
    1,702
    Is that similar to a BF Hammer?
  6. #5
    69
    82,286
    Don't worry about it Chubby. You're not very likely to create any sparks and even if you did, the tank is still sealed until the retaining ring is off and the pump is pulled. When I did one many years ago on a Chevy Blazer I had to pump down about a half tank of gas. Had buckets of gas all over the place.
  7. #6
    Apr 2007
    The Ocean State
    53
    3,516
    I figured I'd run the tank down to ~3 gallons or so left before I start. Part of my hesitance is that my car has lived its whole life in the salt-laden Northeast so I expect the corrosion factor to be substantial I suppose pulling the cover off and having a look would be a good first step. I always worry about resealing the fuel line connections so they don't leak, although these look to be fairly simple to disconnect. And since my garage isn't heated its going to be a chilly job, unless I get out my propane bullet heater Probably not the best idea
  8. #7
    69
    82,286
    Technically, you are better off with a full tank. An empty tank is full of fumes and much more explosive than a full tank.
  9. #8
    Apr 2007
    The Ocean State
    53
    3,516
    Why would you pump the tank down if you should start with a full tank?
  10. #9
    69
    82,286
    Because I did not have an access panel and had to drop the tank. I needed to lighten it.
  • You may not post replies
