| Northstar Performance and Technical Discussion Performance discussions relating to the Northstar System (intake, exhaust, cam, etc.). | Cadillac Forums: Head Gasket Repair in Alaska
01-14-09, 10:39 PM
| | Cadillac Owners Member Cadillac(s): 1998 Deville | | Join Date: Jan 2009 Location: Palmer, Alaska | | | Head Gasket Repair in Alaska Does anybody know of a good independent Northstar mechanic in Alaska?
I need a head gasket job, not sure if I can do it myself (I've done a 350 once, a long time ago) and 97Eldo is just too dang far away!
Called one shop and they wouldn't touch it, called the local dealer (Alaska Sales and Service, Wasilla, AK) and haven't heard back from them yet, but I'm expecting $3k-$5k.
Can a guy really do the head gaskets himself?
Thanks, |
01-14-09, 10:47 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: Head Gasket Repair in Alaska Several people here have done it. |
01-14-09, 11:29 PM
| | Cadillac Owners Connoisseur Cadillac(s): 94 ETC,97 STS | | Join Date: Sep 2003 Location: Arizona | | | Re: Head Gasket Repair in Alaska I've done a few. They are long and tedious, not extremely difficult. Perseverance is you most important requirement. Keeping the parts well organized is important also. There are several threads. Tateos did his and has a pretty big thread with tips. Here's my writeup: http://www.cadillacforums.com/forums...ir-part-i.html (N* Head Gasket repair part I/ Remove engine) |
01-15-09, 01:56 AM
| | Cadillac Owners Member Cadillac(s): 1998 Deville | | Join Date: Jan 2009 Location: Palmer, Alaska | | | Re: Head Gasket Repair in Alaska What's long and tedious? 20 hours? 30 hours?
Are the studs manufactured by 97Eldo worth the hassle saved from not having to do the timeserts?
What can one expect to pay for parts? I think head gaskets are what, $50 ea., timeserts are ? studs are $500 I think, misc. supplies etc. maybe $1,000?
I'll read some more posts, thanks for all the help. |
01-15-09, 08:55 AM
|  | Owner of Northstar Performance Cadillac(s): 97,98,99 STS-97 Eldo- 01 Deville, 04 Bonneville GXP | | Join Date: Mar 2007 Location: Langton, Ontario | | | Re: Head Gasket Repair in Alaska Head gaskets are about $22 each, studs are $549 for the set including all the hardware/drill bit/tap/fixture/threadlocker/etc. No need to buy new bolts when using the studs. If you go with time-serts or Norm's serts, use new bolts.
If you don't need to replace too many parts you can do the whole job for around $800 yourself. It's time-consuming, You can probably get it done in 30-40 hours, that's my guess. |
01-15-09, 11:20 AM
| | Cadillac Owners Member Cadillac(s): 1999 Eldorado | | Join Date: Apr 2006 Location: Mass. | | | Re: Head Gasket Repair in Alaska 97EldoCoupe,
I don't mean to hijack this thread, but I have a question.
When the headgaskets went in my Son's '99 Eldo I had a very reputable shop here in Mass. put another engine in. It came with a 2 year warranty and it ran flawlessly for those 2 years. They are considering giving me another 2 years of warranty for another $325.00 which sounds like a no-brainer, but here's my question. Do you know anyone closer than 600 miles away that will do the headgaskets for $1500 like you ? I'm in this car for the longhaul and I really wouldn't mind putting that much more money in it if this engine develops the same problem, which unfortunately is a good possibility
I would take my chances on this engine being okay for a while, but then have a backup plan to get them done properly if they do fail....
Any thoughts ?
Thanks, Mark  |
01-15-09, 12:55 PM
|  | Owner of Northstar Performance Cadillac(s): 97,98,99 STS-97 Eldo- 01 Deville, 04 Bonneville GXP | | Join Date: Mar 2007 Location: Langton, Ontario | | | Re: Head Gasket Repair in Alaska ZR1, At the moment, no I don't know of anyone else. But I'm seriously looking into expanding into the US somehow, either through franchising or directly setting up shops, or offering contact work to existing shops.
That $325 would be VERY well worth it. That is, if they're serious about keeping their word because if those are the original gaskets in the replacement engine, more than likely they will fail in the next two years. That's a very bad gamble on their part but a very good deal for you.
The $1500 HG job will remain the same price for as long as I can. If parts go up in price I have to raise my price, but luckily I've managed to negotiate some parts discounts. What I need is to expand into the US and further into western Canada. Maybe in the near future.
Part of the reason I can do the job for $1500 is because if GM does it, all of a sudden you need a long list of new parts. I've seen a customer charged for a new exhaust manifold because the old one was warped. OK- there's 8 bolts holding the manifold to the head. Very doubtful they'll ever warp at all. Sure, it's nice to replace almost every part with new, but most of the time you don't need to. |
01-15-09, 04:41 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 1997 ETC, 2000 DTS | | Join Date: Jul 2007 Location: FOUNTAIN HILLS, AZ Age: 53 | | | Re: Head Gasket Repair in Alaska Quote:
Any thoughts ?
Thanks, Mark  | Hi Mark - my wife is coming your way to visit family in Cambridge - I heard it is cold there - single digits - too bad - it is in the 70s and sunny here in Phoenix for Zonie and me- Ha-Ha! |
01-15-09, 10:30 PM
| | Cadillac Owners Member Cadillac(s): 1998 Deville | | Join Date: Jan 2009 Location: Palmer, Alaska | | | Re: Head Gasket Repair in Alaska I just checked with a junkyard, and can get a used engine with about 90K miles on it for $1500. I'm thinking of swapping the engines, then replacing the head gaskets in the original engine, then I'll have a spare. What do ya'll think? I know it means pulling an engine twice, but I'm getting the feeling that's actually not the bad part.
97EldoCoupe, when it comes time, I'm pretty sure I'll go with your studs, thanks for the information.
I await the groups collective wisdom with an open mind. |
01-15-09, 11:07 PM
| | Cadillac Owners Connoisseur Cadillac(s): '05 Dodge RAM Daytona, '67 Cutlass 'vert, 96 Dodge B1500 van | | Join Date: Oct 2003 Location: Florida Age: 38 | | | Re: Head Gasket Repair in Alaska Quote:
Originally Posted by 97EldoCoupe Head gaskets are about $22 each, studs are $549 for the set including all the hardware/drill bit/tap/fixture/threadlocker/etc. No need to buy new bolts when using the studs. If you go with time-serts or Norm's serts, use new bolts.
If you don't need to replace too many parts you can do the whole job for around $800 yourself. It's time-consuming, You can probably get it done in 30-40 hours, that's my guess. | What about the special tools he will need to do the job? |
01-15-09, 11:13 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: Head Gasket Repair in Alaska Quote:
Originally Posted by olsonscottm I just checked with a junkyard, and can get a used engine with about 90K miles on it for $1500. I'm thinking of swapping the engines, then replacing the head gaskets in the original engine, then I'll have a spare. What do ya'll think? I know it means pulling an engine twice, but I'm getting the feeling that's actually not the bad part.
I await the groups collective wisdom with an open mind. | The other option would be to stud the yard engine before installation and do it once. |
01-15-09, 11:39 PM
|  | Owner of Northstar Performance Cadillac(s): 97,98,99 STS-97 Eldo- 01 Deville, 04 Bonneville GXP | | Join Date: Mar 2007 Location: Langton, Ontario | | | Re: Head Gasket Repair in Alaska Why not do the one your car has and save some money? So many people insist in getting a junkyard engine. Only beneficial if your engine is no good. Could you give us some details on what's wrong with it? Just the HGs? |
01-16-09, 12:08 AM
| | Cadillac Owners Connoisseur Cadillac(s): 94 ETC,97 STS | | Join Date: Sep 2003 Location: Arizona | | | Re: Head Gasket Repair in Alaska Quote:
Originally Posted by olsonscottm Q. What's long and tedious? 20 hours? 30 hours?
A. I'd say at least 40 on the first one, significantly less as you do more. 97Eldo has it down...he probably does them in his sleep by now.
Q. Are the studs manufactured by 97Eldo worth the hassle saved from not having to do the timeserts?
A. That's up to you. Timsesrts, Norms, and 97 Eldo's are each different. I think the strength is much better on 97Eldo's and Norm's but the process is similar.
Q. What can one expect to pay for parts? I think head gaskets are what, $50 ea., timeserts are ? studs are $500 I think, misc. supplies etc. maybe $1,000?
A. I'd change some of the "reuseable" gaskets as they get hard with age. I think in the lower 48 it cimes out about $800
Some of the tools can be loaned from Checker or Autozone. Not sure what you have there.
I'll read some more posts, thanks for all the help. | I put the answers above. |
01-16-09, 02:53 AM
| | Cadillac Owners Member Cadillac(s): 1998 Deville | | Join Date: Jan 2009 Location: Palmer, Alaska | | | Re: Head Gasket Repair in Alaska The car has 128K miles on it. I don't know what kind of life to expect out of the transmission and front end, etc.
My thinking with the junkyard engine is that I can then leisurely (and as money comes available) fix the original engine.
To put some dollars on it, I paid $2600 for the car, which I hope to get some back, but I'm not counting on it (posted in another thread). Add $1500 for a used engine and I'm up to $4100. If I do the head gaskets on the original engine, do I need to worry about the air conditioner compressor failing? the blower motor? I just don't know where it will all end.
I don't mind tinkering, but usually it's for some economic benefit (even if only in my mind). The other key factor, which I may not have mentioned, is I was planning on using the car to commute about 100 miles a day. While it doesn't get 30-35 miles to the gallon, it does get 25 or a little better, which if the vehicle is paid for, is fine with me. So, in about 4 years, I'll put about 100K miles on the car. Maybe I'm asking for too much.
It's late, and I'm rambling. Thanks for listening, and providing insight. I am digesting everything everybody has said, it may just be a week or two before I can make up my mind. Indecision can be so time consuming.
I'll post more later. |
01-16-09, 10:54 AM
Originally Posted by olsonscottm Indecision can be so time consuming.
Hmmmmmmmmmmmmm, give me some time to think about that... LOL  | | Cadillac Discussion Tools | | |
Censor is ON | | | |
