  Follow CadillacOwners on Twitter
Go Back   Cadillac Owners Group > General Discussion > Cadillac Engine Technical Discussion > Northstar Performance and Technical Discussion
Northstar Performance and Technical Discussion Performance discussions relating to the Northstar System (intake, exhaust, cam, etc.).
Cadillac Forums: EGR or something worse? Please help! '96 SLS
Old 01-08-09, 05:51 PM
Cadillac(s): '96 SLS
View CaddyQueen30's Photo Album
Casino Cash: $410
I have a 1996 SLS with about 86K on it.
Ok *sigh* My error codes were P0300 (Engine misfire) and P1406 (EGR Valve Pintle Position Circuit). Bear with me guys...I'm a rookie. So I changed the plugs out using the ACDelco platinums, plug wires were only about a year old and still in great condition, threw in a new air filter and - hahahaha - that I was going to clean my EGR. The P0300 code was cleared, so I guess the plug change took care of it? But I'm still getting the P1406.
Here's what my car is doing: When I get in to start it up in the morning - when I havent driven it in 8 or more hours - it starts fine. If I drive it anywhere and turn it off and leave it sitting for more than 5 minutes, when I try to start it again, the ignition is turning over (think ja-ja-ja-ja-ja-ja said real fast...thats the sound), but it takes a good 5 to 10 seconds to catch and start! Here's the kicker: If I get back in within 5 minutes of shutting it off, I can get back in and it starts up no problem. If I wait any longer than 5 minutes, I go through the whole ja-ja-ja-ja thing.
Ok, problem # 2: When I run it up a hill (unavoidable since I live on one), then come to a stop, putting the car in park, the idle goes crazy. It revs a little, then slows to almost sounding like it might die, then revs again, then slows again etc... a few times. Now wait, because if you read above, it does this revving/slowing thing right after it goes through the starting issue I'm talking about too. I havent noticed that it does this when I'm still in gear (like being at a light after coming up a hill). Pretty much just in park I think.
It seems to me that it might be connected.
One last thing: (and you thought I was done!) When I accelerate (only when cold) alot at once, SOMETIMES it hesitates before it accelerates...but not always.
I really need help! Could all this be related to one particular issue? I'm so frustrated!! Any help would be sincerely appreciated.
  #2 (permalink)
Old 01-08-09, 06:22 PM
View Ranger's Photo Album
Casino Cash: $28231
Re: EGR or something worse? Please help! '96 SLS
OK, first off I know you are new. Tech Tips is for posting repair tips. I'll move this to the Northstar section for you.
Your problem sounds like a leak FPR (Fuel Pressure Regulator). Remove the silver beauty cover and locate the FPR on the fuel rail. It is a small canister with a vacuum hose on it. Pull the vacuum hose while at idle and look for any fuel leakage from the nipple. If there is any, the FPR needs to be replaced.
  #3 (permalink)
Old 01-08-09, 07:11 PM
Casino Cash: $410
So you think all of these things are related?
  #4 (permalink)
Old 01-08-09, 07:24 PM
Casino Cash: $28231
Quite possibly. A leaky FPR is putting unmetered raw fuel into the intake manifold. Kind of like a choke on a carburetor, it will aid in cold starts and hinder hot starts. Exactly what you described. Might also cause problem #2 & #3. Check the FPR. If bad, replace it and see if it cures all 3 issues. If not, we'll go from there.
  #5 (permalink)
Old 01-08-09, 07:43 PM
Casino Cash: $410
I'll make it happen and let you know. YOU'RE AWESOME!
  #6 (permalink)
Old 01-08-09, 07:56 PM
Casino Cash: $28231
Ah shucks!
  #7 (permalink)
Old 01-09-09, 05:28 PM
Casino Cash: $410
Did I tell you you're awesome? Thats totally what it was! Now...............heh heh...can I replace the FPR or should I take it to a shop? I am pretty mechanically inclined.
  #8 (permalink)
Old 01-09-09, 06:54 PM
Casino Cash: $28231
Well, if you are mechanically inclined it is a pretty easy swap. Bleed off the fuel pressure first. Easiest way is to remove the cap on the service port and hold a rag over it while pressing the schreader valve. Just like letting air out of a tire. Should get about an oz. of gas out. Then pull the retainer clip and remove the old FPR. Look close though. I think there are 2 "O" rings. Be sure one does not stay down in the housing and once you put it back together check, double check and triple check for leaks. Someone in a recent thread just replaced it and had a massive leak that started a fire.
  #9 (permalink)
Old 01-09-09, 07:40 PM
Casino Cash: $410
Super! I'm picking up the part after work tonight. I'll have it on by tomorrow afternoon. Keep your fingers crossed that it takes care of all the issues!
Thanks Ranger!!! ((((My Hero))))
  #10 (permalink)
Old 01-09-09, 07:47 PM
Casino Cash: $28231
Flattery will get you everywhere. Let us know it that solves all your problems. I suspect it might.
  #11 (permalink)
Old 01-09-09, 11:54 PM
Casino Cash: $410
Yessir!!!! I put it in this evening and guess what? NO PROBLEM with my start...NO PROBLEM with the idle after I drove up a hill. No more hesitation upon acceleration!!! She's running so smooth I'm in love all over again! LOL Thank you SO much! (My Dad, who's a motorcycle mechanic said "well dang, I even learned something new today!" when he watched me swap the FPR's out.) Ranger, if you were in Seattle, I'd buy you a drink or two!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I owe you!! You have earned yourself a fan!
  #12 (permalink)
Old 01-10-09, 01:05 PM
Casino Cash: $28231
WOW! A girl who knows her way around under the hood. I'm impressed! Glad I was able to help and that you are in love with your car again. Nothing better that having your car return the favor when you turn it on. Now I know where I can get a free drink ...... or two.
  #13 (permalink)
Old 01-12-09, 12:05 PM
Casino Cash: $410
Absolutely! Couldnt have done it without you though. I do still need to figure out my EGR issue though. One catastrophe at a time.
  #14 (permalink)
Old 01-12-09, 12:21 PM
Casino Cash: $28231
What EGR issue?
  #15 (permalink)
Old 01-12-09, 03:32 PM
Casino Cash: $410
What EGR issue?
I'm not quite sure yet...I havent researched it yet. I'm getting a P0300 error code, but the wording of the code leads me to believe it may be the wiring of the EGR rather than the part itself. It says something like Pintle Valve Circuit (I cant remember exactly what it says, I'd have to run it again). When I was looking at it while I was dealing with the FPR though, the wiring didnt look great, and the connector didnt look super either. I really just need some time to inspect I guess. Oh, The dash readout says "Service Emissions". I thought I told you about this. Sheesh...I might be losing it
Tags: ,
egr, sls, worse
attach your bluetooth cell phone to onstar
flash wax for your cadillac
cadillac key wraps
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
custom floor mats | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | air suspension kits | air suspension parts | air ride suspension | hyundai genesis forum
